Catalyst 4006 support for Dual MSFC
Can anyone tell me if a Catalyst 4006 CatOS 5.4(2) will support redundant WS-X4013 SUP II interfaces?
I looked all over the Cisco Documentation and could not find a definative answer.
1 ACCEPTED SOLUTION
Re: Catalyst 4006 support for Dual MSFC
Supervisor redundancy is available in 4507 and 4510 series only .
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_data_sheet09186a008033a3bd.html
Hope this helps
regards
vanesh k
Hope this helps
regards
vanesh k
Thanks, I did more reading and came to the same conclusion.
From what I have read, the Catalyst 4000 is a Layer 2 only switch and does not support any routing.
Cat4006 support Layer3 routing as well using a layer3 module 4232-L3, but these cannot be installed as redundent modules.So with 4006 there is no module redundancy available.
-amit singh
165
