catalyst 4500 sup 7E qos etherchannel
Has anyone been able to configure successfully?  I followed the example and broke customers uplink as a result for about 12 minutes and the ommand wasn't on once it came back. Obviously hesitant to put it on again. Just to mention you cannot police and queue on the same policy for either the physical interfaces that make up the etherchannel or on the port channel interface.  This is what the doci indicates is the way to do it.
policy-map p1
class voice
police cir   30000000
policy-map p2
class voice
priority
int port-channel1
service-policy output p1
ing gig1/1
channel-group 1
service-policy output p2
as always thanks
1 REPLY
Is this the config that broke connectivity for 12 min? Not quite sure why it would cause an outage.
I believe you are referring to a known software limitation:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsq67430
The Sup6-E and Sup7-E divide policies into "queueing" and "non-queuing"
actions. On an etherchannel, the queueing actions must be applied to the
port-channel interface and the non-queueing actions must be applied to
the physical member interfaces.  In other words, you'll need to create
two different service policies and apply one to the port-channel
interface and the other to the physical member interface.
Example queueing actions within a policy-map: priority, bandwidth,
bandwidth remaining, dbl
Example on-queueing action within a policy-map (policing and marking):
set dscp, set ip prec, set qos, police
Fabienne
LAN-Switching TAC
827
