Catalyst 4500-X-16 SFP+ - uninterrupted output
jeremygoutal
I am trying to configure a VSS with 2 Catalyst 4500-X. To do this I have to upgrade my IOS to cat4500e-universalk9.SPA.03.05.00.E.152-1.E as it is the one needed to support this functionality.
The upgrade works fine, but afterwards, when I log in to my switch via console, I get 5/10 secs of normal usage, and then an uninterrupted flow of "^@".
Example :
Switch#^@
Switch#^@
Switch#^@
Switch#^@
Switch#^@
Switch#^@
Switch#^@
Switch#^@
Switch#^@
Switch#^@
Switch#^@
Switch#^@
and so on. I am unable to do anything about it. The same thing happens with either TeraTerm, SecureCRT or Putty.
Before my upgrade I had this configuration for my console line :
line con 0
escape-character 3
to have "Ctr+C" as break key. I thought it might be the issue, so I put it back as default, but no luck :
line con 0
escape-character BREAK
I am willing to listen to any ideas, I really am lost here. The next step would be to downgrade but I am reluctant to do so.
Thank you
IOS-XE 3.5.0 SG also requires you upgrade the ROMMON if you plan to use VSS. Reference.
As you found out, 3.4.1 works fine and supports VSS without ROMMON upgrade. (3.4.0 technically supports VSS but should be avoided as it had some bugs in that initial VSS-supporting release.)
jeremygoutal
For those wondering about this, I still had to downgrade to the previous IOS version available on Cisco website :
cat4500e-universalk9.SPA.03.04.01.SG.151-2.SG1.bin
Works like a charm now... I don't know if anyone encountered the same issue, but it is resolved now.
