Catalyst 4507R+E (Sup 7-E) with WS-X4748-SFP-E blade. Ports not working properly
firstly I have inserted a WS-X4748-SFP-E blade into Catalyst 4507R+E (Sup 7-E) runing Version 03.04.03.SG.(151-2.SG3) but the blade were unsupported, so that i upgraded to Version 03.05.03.E (152-1.E3) and the ROMMON to 15.0(1r)SG7.
Now the blade is allowed and shown as OK in "sh module".
When i plug the GBICs and connect them with fiber optic but traffic is not forwarded.
Additionally the SFPs are not listed in "sh int transceiver"
sh module
Chassis Type : WS-C4510R+E
Power consumed by backplane : 40 Watts
Mod Ports Card Type                              Model              Serial No.
 1    48  10/100/1000BaseT EEE (RJ45)            WS-X4748-RJ45-E    CAT1806L2DK
 2    48  1000BaseX SFP                          WS-X4748-SFP-E     CAT1804L19F
 5     4  Sup 7-E 10GE (SFP+), 1000BaseX (SFP)   WS-X45-SUP7-E      CAT1743L0E8
 6     4  Sup 7-E 10GE (SFP+), 1000BaseX (SFP)   WS-X45-SUP7-E      CAT1813L03N
 M MAC addresses                    Hw  Fw           Sw               Status
 1 7426.ac47.7d8c to 7426.ac47.7dbb 1.2                               Ok
 2 a80c.0dea.cc7c to a80c.0dea.ccab 1.0                               Ok
 5 78da.6ec8.8180 to 78da.6ec8.8183 2.1 15.0(1r)SG7  03.05.03.E       Ok
 6 78da.6ec8.8184 to 78da.6ec8.8187 2.1 15.0(1r)SG7  03.05.03.E       Ok
Mod  Redundancy role     Operating mode      Redundancy status
 5   Standby Supervisor  SSO                 Standby hot
 6   Active Supervisor   SSO                 Active
sh int transceiver
If device is externally calibrated, only calibrated values are printed.
++ : high alarm, +  : high warning, -  : low warning, -- : low alarm.
NA or N/A: not applicable, Tx: transmit, Rx: receive.
mA: milliamperes, dBm: decibels (milliwatts).
                                 Optical   Optical
           Temperature  Voltage  Tx Power  Rx Power
Port       (Celsius)    (Volts)  (dBm)     (dBm)
Te5/1        28.2       3.29      -2.7     -29.5
Te6/1        29.4       3.30      -2.4     -32.2
sh interfaces gi2/1 accounting
GigabitEthernet2/1
                Protocol    Pkts In   Chars In   Pkts Out  Chars Out
                   Other          0          0          3        528
           Spanning Tree         46       6946         46       5474
                     CDP          1        172          1        500
Everyone's tags (1)
VIP Super Bronze
Is the SFP ports in up and up
Is the SFP ports in up and up mode when connected to a device?
yes they are. I can see the
yes they are. I can see the neighbor switch connected to that port via cdp or lldp.
I have reseted the module more than 2 times and for the moment it seems as it works. Very Strange!!!! However I don't know if i can reproduce it again.
sh int gi2/1 | i packe
  5 minute input rate 1212000 bits/sec, 1859 packets/sec
  5 minute output rate 23000 bits/sec, 55 packets/sec
     4520378 packets input, 393342775 bytes, 0 no buffer
     1223906 packets output, 109919044 bytes, 0 underruns
Should the SFPs not be shown in "sh int transceiver"? it still showing only the SFP+ on the Sup 7-E
VIP Super Bronze
The sh int tran you provided
The sh int tran you provided is for port 5/1 and 6/1 but you are having issue gi2/1?
so what is the output of sh int tra gi2/1?
this is what i mean!! the SFP
this is what i mean!! the SFP is pluged in gi2/1 but it's not shown in "sh int trans"!?
sh idprom interface g2/1
GBIC Serial EEPROM Contents:
Common Block:
 Identifier        = SFP [0x3]
 Extended Id       = GBIC is compliant with MOD_DEF 4 [0x4]
 Connector         = LC Connector [0x7]
 Transceiver
  Type             = Gbic 1000BaseSX
  Speed(FC,byte 10)= Not available [0x0]
  Media            = Not available [0x0]
  Technology       = Not available [0x0]
  Link Length      = Not available [0x0]
  GE Comp Codes    = 1000BASE-SX  [0x1]
  SONET Comp Codes = Not available [0x0]
  10GE Comp Codes = Extended  [0x0]
 Encoding          = 8B10B  [0x1]
 BR, Nominal       = 1300 Mbps (million bits per second)
 Length(9u) in km  = GBIC does not support single mode fibre, or the length
                     must be determined from the transceiver technology.
 Length(9u)        = GBIC does not support single mode fibre, or the length
 Length(50u)       = 550 m
 Length(62.5u)     = 270 m
 Length(Copper)    = GBIC does not support copper cables, or the length must
 Vendor name       = CISCO
 Vendor OUI        = 5994
 Vendor Part No.   = SFBR-5716PZ
 Vendor Part Rev.  = 001
 Wavelength        = 850 nanometers
 CC_BASE           = 0x3E
Extended ID Fields
 Options           = Loss of Signal implemented TX_FAULT signal implemented TX_DISABLE is implemented and disables the serial output Linear Receiver Output implemented  [0x1A]
 BR, max           = Unspecified
 BR, min           = Unspecified
 Vendor Serial No. = AGJ1807RBT2
 Date code         = 140214
 Diag monitoring   = Implemented
 Calibration type  = Internal
 Rx pwr measuremnt = Average Power
 Address change    = Not required
 CC_EXT            = 0x3D
Vendor Specific ID Fields:
80CFD1CC  00 00 06 DD A9 D8 B4 5B 77 00 23 9C A9 B7 54 CE   ....)X4[w.#^\)7TN
80CFD1DC  09 28 04 00 00 00 00 00 00 00 00 00 A1 60 3C E0   .(...........`<`
SEEPROM contents (hex) size 128:
0x0000  03 04 07 00 00 00 01 00 00 00 00 01 0D 00 00 00   ................
0x0010  37 1B 00 00 43 49 53 43 4F 20 20 20 20 20 20 20   7...CISCO
0x0020  20 20 20 20 00 00 17 6A 53 46 42 52 2D 35 37 31       ...jSFBR-571
0x0030  36 50 5A 20 20 20 20 20 30 30 31 20 03 52 00 3E   6PZ     001 .R.>
0x0040  00 1A 00 00 41 47 4A 31 38 30 37 52 42 54 32 20   ....AGJ1807RBT2
0x0050  20 20 20 20 31 34 30 32 31 34 20 20 68 F0 03 3D       140214  hp.=
0x0060  00 00 06 DD A9 D8 B4 5B 77 00 23 9C A9 B7 54 CE   .....X4[w.#^\.7T.
0x0070  09 28 04 00 00 00 00 00 00 00 00 00 A1 60 3C E0   .(..........!`<`
851
