Community Member
Catalyst 4510 with Sup v-10GE (model WS-x4516-10GE) Issues!!!
My supervisor blades have 2 10GE ports and 4 GE ports on them. I have 2 supervisor blades on my 4510. I was wondering if I can use all 8 (4 on 1st blade and 4 on the 2nd blade) at the same time. I do not plan on using the 10GE ports.
1 ACCEPTED SOLUTION
Re: Catalyst 4510 with Sup v-10GE (model WS-x4516-10GE) Issues!!
Unfortunately I don't believe that will work. You will only be able to use 2 1G SFP's per supervisors giving you a total of four.
When two Supervisor Engine V-10GEs are present in a Catalyst 4510R or Catalyst 4507R switch, two SFP uplinks are active on both the primary (active) and secondary (standby) supervisor engines by default, or four uplinks will be active in a nonredundant configuration.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/hardware/configuration/notes/78_16727.html#wp112187
HTH,
Mark
HTH,
Mark
Community Member
So, I would need to add an SFP blade (such as a WS-X4506-GB-T)in order to get more GIG interfaces? Correct?
Brian,
That is correct. You would need an additional blade to satisfy your requirement.
HTH,
Mark
Community Member
Thanks Mark!!!
Community Member
Are these blades Hot Swappable too???
Yes, They are hot swappable.
366
