Catalyst 4510R+E 1000BASE-T Module Stops Accepting New Links
mjhendriks
We have a 4510R+E which is configured as follows:
Chassis Type : WS-C4510R+E
Power consumed by backplane : 40 Watts
Mod Ports Card Type                              Model              Serial No.
1    48  10/100/1000BaseT (RJ45)                WS-X4648-RJ45-E    JAE144006T7
2    48  10/100/1000BaseT Premium POE E Series  WS-X4748-RJ45V+E   CAT1437L10Q
3    48  10/100/1000BaseT (RJ45)                WS-X4648-RJ45-E    JAE1440071K
4    48  10/100/1000BaseT (RJ45)                WS-X4648-RJ45-E    JAE14420A9J
5     4  Sup 7-E 10GE (SFP+), 1000BaseX (SFP)   WS-X45-SUP7-E      CAT1449L09Q
6     4  Sup 7-E 10GE (SFP+), 1000BaseX (SFP)   WS-X45-SUP7-E      CAT1450L217
7    48  10/100/1000BaseT (RJ45)                WS-X4648-RJ45-E    JAE14390T00
8    48  10/100/1000BaseT (RJ45)                WS-X4648-RJ45-E    JAE14400PIO
9    48  10/100/1000BaseT Premium POE E Series  WS-X4748-RJ45V+E   CAT1437L0Z5
10    48  10/100/1000BaseT Premium POE E Series  WS-X4748-RJ45V+E   CAT1437L024
M MAC addresses                    Hw  Fw           Sw               Status
1 xxxx.xxxx.fd47 to 1cdf.0f7d.fd76 1.0                               Ok
2 xxxx.xxxx.b7c0 to 0026.992c.b7ef 1.0                               Ok
3 xxxx.xxxx.2365 to 1cdf.0f7e.2394 1.0                               Ok
4 xxxx.xxxx.1aaf to c84c.7513.1ade 1.0                               Ok
5 xxxx.xxxx.a4c0 to c471.feb5.a4c3 1.0 15.0(1r)SG2  03.02.01.SG      Ok
6 xxxx.xxxx.a4c4 to c471.feb5.a4c7 1.0 15.0(1r)SG2  03.02.01.SG      Ok
7 xxxx.xxxx.f8ac to 1cdf.0f7d.f8db 1.0                               Ok
8 xxxx.xxxx.4d37 to 588d.0949.4d66 1.0                               Ok
9 xxxx.xxxx.b790 to 0026.992c.b7bf 1.0                               Ok
10 xxxx.xxxx.9b70 to 0026.992c.9b9f 1.0                               Ok
Mod  Redundancy role     Operating mode      Redundancy status
5   Active Supervisor   SSO                 Active
6   Standby Supervisor  SSO                 Standby hot
Occasionally, a module in the chassis will stop accepting new links.  That is, a cable plugged into a port on the module, with a working host on the other end, will not result in a link being brought up.  Trying a port on another module works just fine.  Existing connections on the affected module are stable.  If an existing connection is unplugged and plugged back in, the link will not come back up.  Issuing a hw-module module x reset command will reboot the module, and new links will start working again.  We have had three different modules in different slots affected by this problem.
I'm considering a software upgrade, but haven't found reference to any specific bugs that mention this problem.
If anyone has any insight, it would be appreciated.
Mike
6 Replies 6
david_casey
Could this be a problem of not enough power in the chassis to support the types and number of modules you have?  What does the show power detail command say?
Dave
I think power is okay.
Power                                             Fan      Inline
Supply  Model No          Type       Status       Sensor   Status
PS1     PWR-C45-4200ACV   AC 4200W   good         good     good
PS1-1                         220V   good
PS1-2                         220V   good
PS2     PWR-C45-4200ACV   AC 4200W   good         good     good
PS2-1                         220V   good
PS2-2                         220V   good
Power supplies needed by system    : 2
Power supplies currently available : 2
Power Summary                      Maximum
(in Watts)              Used     Available
System Power (12V)       1410        2200
Inline Power (-50V)       648        6150
Backplane Power (3.3V)     40          40
Total                    2098 (not to exceed Total Maximum Available = 7600)
Power Measurement    Inline Power (-50V)
(in Watts)             (+/- 50Watts)
PS1                         250
PS2                         200
Total                       450
                             Watts Used of System Power(12V)
Mod   Model                 budgeted instantaneous  peak   out of reset  in reset
1    WS-X4648-RJ45-E           89         --        --         89          10
2    WS-X4748-RJ45V+E          75          47        47        75          35
3    WS-X4648-RJ45-E           89         --        --         89          10
4    WS-X4648-RJ45-E           89         --        --         89          10
5    WS-X45-SUP7-E            260         230       236       260         100
6    WS-X45-SUP7-E            225         221       253       225         225
7    WS-X4648-RJ45-E           89         --        --         89          10
8    WS-X4648-RJ45-E           89         --        --         89          10
9    WS-X4748-RJ45V+E          75          45        46        75          35
10    WS-X4748-RJ45V+E          75          45        46        75          35
--   Fan Tray                 255         --        --        --          --
       Total                  1410         588       628      1155         480
                        Watts used of Chassis Inline Power (-50V)
                        Inline Power Admin  Inline Power Oper
Mod   Model                PS     Device       PS     Device     Efficiency
1    WS-X4648-RJ45-E          -        -          -        -           -
2    WS-X4748-RJ45V+E       267      254        108      103          95
3    WS-X4648-RJ45-E          -        -          -        -           -
4    WS-X4648-RJ45-E          -        -          -        -           -
5    WS-X45-SUP7-E            -        -          -        -           -
6    WS-X45-SUP7-E            -        -          -        -           -
7    WS-X4648-RJ45-E          -        -          -        -           -
8    WS-X4648-RJ45-E          -        -          -        -           -
9    WS-X4748-RJ45V+E       186      176         79       76          95
10    WS-X4748-RJ45V+E       196      186         88       84          95
       Total                 649      616        275      263
That looks fine.  This is odd since you said that just a specific port won't work while other ports on the same module are working fine.  Moving the cable to a different port and it works fine.  I'd open up a TAC case if no one else here ports anything which might be bug related or hit up the bug search tool and see if you can find anything.
Are there any other error or log messages associated with this behavior?
Dave
Other ports on the same module will work fine as long as they are not unplugged (or brought down with a shutdown command, etc.)  The issue specifically seems to be related to the process of bringing the port up.
Unfortunately the log does not show any information related to these events.  A TAC case is definitely my next step, I just wanted to check here first.
According to TAC, we're suffering from this:
CSCts67025
• One or more line cards (WS-X46xx and WS-X47xx series) stop responding to interface changes when near-simultaneous      link events (if timed correctly) occur on the same linecard.  Only line cards in the WS-X46xx series and the WS-X47xx      series are affected. Interfaces that are already linked-up are not affected.
     Workaround: Eliminate link flap. If the problem exists, do one of the following:
– Reload the linecard module with the hw-module module n reset command.
– For dual supervisor engines, perform a switchover. CSCts67025
It looks like I'm also experiencing this bug but I'm running WS-X45-SUP6-E with WS-X4648 and WS-X4548 blades.  I've had the interfaces stop responding to link changes as well as stop providing PoE.  It also caused the CPU to remain at 70% utilization.  I performed the hw-module reset on the problem WS-X45xx blades and that resolved the interface and high CPU issues.  I'm just wondering if anyone else has seen this bug show up on the SUP6-E's and WS-X45xx line cards and what version of IOS 15 is recommended?
