Catalyst 4948 10G drops packets
zzs-bzwbk
All of our C4948-10G have increasing "output drops" counters. Here's the example of port statistics (this is a SPAN port that drops packets continously
when port load is about 200Mbps/50k pps).
GigabitEthernet1/1 is up, line protocol is down (monitoring)
  Hardware is Gigabit Ethernet Port, address is 0021.d809.6100 (bia 0021.d809.6100)
  Description: SPAN
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 45/255, rxload 1/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000-TX
  input flow-control is on, output flow-control is off
  Last input never, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 853098790
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 177443000 bits/sec, 45447 packets/sec
     3989 packets input, 5036752115 bytes, 0 no buffer
     Received 3989 broadcasts (0 multicasts)
     1804766864558 packets output, 1290148458844910 bytes, 0 underruns
     0 lost carrier, 0 no carrier
What can be the cause of such behavior? Is 50K pps too much for 1Gig port of 4948?
WM
Dale Miller
I suspect the drops are caused by bursty traffic overrunning the egress buffer. Currently you PPS and Output rate is averaged over a 5 minute period and you can't indentify microburst of traffic. If the destination port is connected to a sniffer or PC with wireshark you can use the IO graph to see the problem. I understand you will not exceed 1GB as the packets are dropped before it is on the wire but at least you have a graphical representation of the traffic.
Using Wireshark
Statistics--> IO Graph
Configure the X Axis to .001 tick interval
Configure the Y Axis to bits per tick
If you have a spike nearing 1,000,000 bits in a .001 interval you close to 1Gb. I have attached an IO Graph showing spikes at 1GB on a 100 Mbs flow.
Dale
