Catalyst 6000 config
yvannpaillet
Could you tell me if this config can work please:
-Catalyst 6506 enhanced 6-slot shassis 12U
-Catalyst 6500 Super.Engi-2,2GE+MSFC2/PFC-2
-Catalyst 6500 48-ports Gig-E Mod:(req.SFP)
Think you for your help.
5 Replies 5
Jon Marshall
Could you provide part number of 48 port module ie.
WS-X6???
If the module is a WS-X67xx module part number then you cannot use this with a supervisor 2, you will need a sup 720.
Jon
Ok it's the WS-X6748.
Which sup. engine should i used
If you want to use the WS-X6748-GE-TX then you have to have a Sup720 ie. you cannot use a Sup1a, sup2 or a sup32.
Jon
I can i use the WS-X6748-SFP on the Sup 720 ?
Yes
