Community Member
Catalyst 6000 Sup1A-2GE error message
on a 6000 SUP1A-2GE + MSFC (CatOS 7.6-10) we have the following logs :
As anyone an idea of the problem, i have not found any related docs opn the CCO.
Thank You,
Mickael.
NVRAM log:
01. 4/7/2008,20:41:20: titan_intr_hdlr: Main Intr 0x0; Module 0x0, value 0x0;
fatal intrs since last read 0, Last DBus Src Index 0x0
02. 4/7/2008,20:41:20: L3 Fwding Engn Intr:L3 parity mismatch rectified 12535 0x
7491 0x0x400000 0x0x80861ef 0x0
03. 4/7/2008,20:41:20: titan_intr_hdlr:Last titan interrupt occurred at 00:00:00
.0
04. 4/7/2008,20:41:20: titan_intr_hdlr: Main Intr 0x0; Module 0x0, value 0x0;
05. 4/7/2008,20:41:20: L3 Fwding Engn Intr:L3 parity mismatch rectified 12535 0x
749b 0x0x400000 0x0x80861ef 0x0
06. 4/7/2008,20:41:20: titan_intr_hdlr:Last titan interrupt occurred at 00:00:00
.0
07. 4/7/2008,20:41:20: titan_intr_hdlr: Main Intr 0x0; Module 0x0, value 0x0;
08. 4/7/2008,20:41:20: L3 Fwding Engn Intr:L3 parity mismatch rectified 12535 0x
74a5 0x0x400000 0x0x80861ef 0x0
09. 4/7/2008,20:41:20: titan_intr_hdlr:Last titan interrupt occurred at 00:00:00
.0
10. 4/7/2008,20:41:20: titan_intr_hdlr: Main Intr 0x0; Module 0x0, value 0x0;
11. 4/7/2008,20:41:20: L3 Fwding Engn Intr:L3 parity mismatch rectified 12535 0x
74af 0x0x400000 0x0x80861ef 0x0
12. 4/7/2008,20:41:20: titan_intr_hdlr:Last titan interrupt occurred at 00:00:00
.0
13. 4/7/2008,20:41:20: titan_intr_hdlr: Main Intr 0x0; Module 0x0, value 0x0;
14. 4/7/2008,20:41:20: L3 Fwding Engn Intr:L3 parity mismatch rectified 12535 0x
74b9 0x0x400000 0x0x80861ef 0x0
15. 4/7/2008,20:41:20: titan_intr_hdlr:Last titan interrupt occurred at 00:00:00
.0
16. 4/7/2008,20:41:20: titan_intr_hdlr: Main Intr 0x0; Module 0x0, value 0x0;
17. 4/7/2008,20:41:20: L3 Fwding Engn Intr:L3 parity mismatch rectified 12535 0x
74c3 0x0x400000 0x0x80861ef 0x0
18. 4/7/2008,20:41:20: titan_intr_hdlr:Last titan interrupt occurred at 00:00:00
.0
19. 4/7/2008,20:41:20: titan_intr_hdlr: Main Intr 0x0; Module 0x0, value 0x0;
20. 4/7/2008,20:41:20: L3 Fwding Engn Intr:L3 parity mismatch rectified 12535 0x
74cd 0x0x400000 0x0x80861ef 0x0
21. 4/7/2008,20:41:20: titan_intr_hdlr:Last titan interrupt occurred at 00:00:00
.0
22. 4/7/2008,20:41:20: titan_intr_hdlr: Main Intr 0x0; Module 0x0, value 0x0;
23. 4/7/2008,20:41:20: L3 Fwding Engn Intr:L3 parity mismatch rectified 12535 0x
74d7 0x0x400000 0x0x80861ef 0x0
24. 4/7/2008,20:41:20: titan_intr_hdlr:Last titan interrupt occurred at 00:00:00
.0
25. 4/7/2008,20:41:20: titan_intr_hdlr: Main Intr 0x0; Module 0x0, value 0x0;
26. 4/7/2008,20:41:20: L3 Fwding Engn Intr:L3 parity mismatch rectified 12535 0x
74e1 0x0x400000 0x0x80861ef 0x0
27. 4/7/2008,20:41:20: titan_intr_hdlr:Last titan interrupt occurred at 00:00:00
.0
28. 4/7/2008,20:41:20: titan_intr_hdlr: Main Intr 0x0; Module 0x0, value 0x0;
1 REPLY
Re: Catalyst 6000 Sup1A-2GE error message
You are possibly hitting CSCdy41174. Try upgrading your code revision. If this doesn't work, the module will likely need to be replaced.
-Ryan
227
