Catalyst 6006 Switch Fault - Require Experienced Engineer
edw
One of our Cataylst switches went into a mode I can't find much info on. The STAUS LED on the Supervisor board (SUP1A) went RED. After a power down and power up nothing is coming out of the console port and it goes straight to RED. Power and Fans are fine - any ideas or help really appreciated!!
Ed
7 Replies 7
glen.grant
Maybe try hitting the little reset button on the supervisor for the console , sometimes you have to change this to get output out of the console , otherwise if you can't get any reading out of the console then it is probably DOA and you will have to get a replacement. Not really a way to even attempt to look at it if you have no console output. You can try a few things like pull all the boards out of the slots and just leave the sup in and see if it will boot , have seen this before where a faulty board in another slot will keep it fromn booting.
Thanks for the reply - I tried the reset button (is there a special trick or just push with paper clip?) This didn't change anything. I have stripped and clean the unit top to bottom and reseated in different slots and order - still no joy.
Should the modules go green or do they wait for the Sup to power up ? The Sup isn't even going orange to say its reading rom or doing diag - literily goes to RED and stays there.
There are two RJ45 sockets on the board - are they of any use ?
Whats the warrenty cover of these - would Cisco take it back and repair it for a charge?
Ed
Leo Laohoo
Hi Ed,
Can you console into the Sup card and watch the output when you do a restart. I'm suspecting (wish I'm wrong) that you may either have a hardware failure or your Sup is booting into ROMmon.
No console on the normal console port - nothing showing. I thnk its hardware but would have through for such an expensive system there would be a few more pointers to show.
Whats ROMmon ?? How would I know if its doing that ?
Ed
Hi, Ed:
From what Im reading on this thread, it sounds as though your SUP model is experiencing a major hardware failure.
I'm not sure you have any recourse but to call Cisco and open a TAC case and hope its still under warranty...
ROMMON is a special boot mode that a switch boots into when it cannot find a usable IOS (operating system). Its almost like your PC booting into Safe Mode.
I dont think that its as simple as that. The SUP wouldnt be acting like this if there was a promleb only with the IOS.
You would know youre in ROMMON mode by consoling into the SUP module and seeing a prompt that looks like this:
rommon>
Victor
Whats the length of warrenty on hardware from Cisco ?
Also does anyone know if a WS-X6K-S2-MSFC2 or a WS-X6K-S2U-MSFC2 would fit in a 6006 chassis ?
Ed
Does anyone know if a WS-X6K-S2-MSFC2 or a WS-X6K-S2U-MSFC2 would fit in a 6006 chassis ?
Ed
