Catalyst 6500 and 4500 Ether-channel load balancing
How can I find out if my load balancing is truly balancing the load across my links? In other words how can I see the traffic load on each of the links in the channel?
Mike
Re: Catalyst 6500 and 4500 Ether-channel load balancing
Hi Burley,
The below chart show the Ether-Channel load balancing.
Number of Ports in the EtherChannel
Load Balancing
8
1:1:1:1:1:1:1:1
7
2:1:1:1:1:1:1
6
2:2:1:1:1:1
But to check real time traffic i suggest you to use SNMP ( Bandwidth monitoring for those switch ports )
It can give you good report that any command line in switch.
Regard
Chetan Kumar
http://chetanress.blogspot.com
Thanks for the chart, I did already look at that. I was checking to see if there was a coomand that would give me some indication as to the load on each of the links.
Mike
Hall of Fame Super Blue
Mike
What if you just look at each interface to see the load/packets transmitted and received. Would that not tell you how it was load-balancing the traffic across the links ? You could clear the counters to get a base to start with.
One other thing - what does "sh etherchannel load-balance" show ? From memory i don't think it shows what you want but can't remember to be honest.
Jon
Jon,
Thanks for pointing out the obvious....some times I wonder about my mind and over thinking the obvoius....
As for the command   sh etherchannel load-balance   it just show what Load Balancing method is in use.
I cleared the counters and I will check later.
Thanks for your Help Jon.
Mike
1293
