01-20-2009 10:19 AM - edited 03-06-2019 03:32 AM
Working with 2 Catalyst 6509 conected via a LACP with 4 ports 1G obtain a very imbalanced traffic distribution. The etherchannel is working with default configuration.
The traffic flow is from clients to servers and the clients begin the connection.
Solved! Go to Solution.
01-21-2009 04:33 AM
Yes you are on the right track just try the others until you find a good balance , it will never be totally equal across all links. Think about how traffic is flowing , is all the traffic going to a single destination tc... then you probably don't want to use destination ip as the criteria. The settings may not even be the same on each end the link .
01-20-2009 03:12 PM
Try one of the other methods . It really hit and miss as far as trying to get them "more" evenly balanced.
01-20-2009 11:49 PM
Hi Glen,
Thanks for your input.
Wich are the other methods?. We are thinking about modify the load-balancing keywords(src IP, src Mac....).
In every etherchannel 4G we are using only perhaps 1,5M and some times have overrun frames on the interfaces
Thanks again
Luis
01-21-2009 04:33 AM
02-04-2009 10:08 PM
Thanks again for your help
Luis
