Catalyst 6509 FlexWAN & PA-A3-OC3 module bootup problem
I have FlexWAN & PA-A3-OC3 module installed at Catalyst 6509 slot 3. Last week this switch reloaded. All configuration back exceptd ATM module configuration. The ATM module configuration still exist at "show start", but not exist at "show runn". I copy ATM module configuration from startup-config to running-config, It work again. Can you please help to identify this problem?
Show Version :
IOS (tm) c6sup2_rp Software (c6sup2_rp-PSV-M), Version 12.1(13)E17, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Thu 25-Aug-05 07:56 by tinhuang
Image text-base: 0x40008C00, data-base: 0x417A8000
ROM: System Bootstrap, Version 12.1(4r)E, RELEASE SOFTWARE (fc1)
BOOTLDR: c6sup2_rp Software (c6sup2_rp-PSV-M), Version 12.1(13)E17, RELEASE SOFTWARE (fc1)
Core-01 uptime is 1 week, 1 day, 4 hours, 54 minutes
Time since Core-01 switched to active is 1 week, 1 day, 4 hours, 53 minutes
System returned to ROM by power-on (SP by power-on)
System restarted at 10:50:51 TWN Sun Jan 13 2008
System image file is "sup-bootflash:c6sup12-psv-mz.121-13.E17.bin"
cisco Catalyst 6000 (R7000) processor with 112640K/18432K bytes of memory.
Processor board ID SAL0551FG7W
R7000 CPU at 300Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
X.25 software, Version 3.0.0.
Bridging software.
1 FlexWAN controller (1 ATM).
16 Virtual Ethernet/IEEE 802.3 interface(s)
48 FastEthernet/IEEE 802.3 interface(s)
22 Gigabit Ethernet/IEEE 802.3 interface(s)
1 ATM network interface(s)
381K bytes of non-volatile configuration memory.
16384K bytes of Flash internal SIMM (Sector size 512K).
Standby is up
Standby has 112640K/18432K bytes of memory.
Configuration register is 0x0
Show Module :
Mod Ports Card Type Model Serial No.
1 2 Cat 6k sup 1 Enhanced QoS (Active) WS-X6K-SUP1A-2GE SAL0601G2K4
2 2 Cat 6k sup 1 Enhanced QoS (Standby) WS-X6K-SUP1A-2GE SAL0604GWCG
3 0 2 port adapter FlexWAN WS-X6182-2PA SAD060600Z3
4 16 16 port 1000mb GBIC ethernet WS-X6416-GBIC SAD05080CJZ
6 48 48 port 10/100 mb RJ45 WS-X6348-RJ-45 SAL0549F43K
7 2 Network Analysis Module WS-X6380-NAM SAD060502TK
Mod MAC addresses Hw Fw Sw Status
1 0006.d65a.5028 to 0006.d65a.5029 7.1 5.4(2) 7.5(0.6)HUB2 Ok
2 0006.d65a.60e0 to 0006.d65a.60e1 7.1 5.4(2) 7.5(0.6)HUB2 Ok
3 0001.6477.d790 to 0001.6477.d7cf 1.4 12.1(13)E17 12.1(13)E17 Ok
4 0001.9724.2eec to 0001.9724.2efb 1.2 5.4(2) 7.5(0.6)HUB2 Ok
6 0005.740c.1da0 to 0005.740c.1dcf 6.0 5.4(2) 7.5(0.6)HUB2 Ok
7 0001.6477.8626 to 0001.6477.8627 1.3 4B4LZ0XA 2.1(1a) Ok
Mod Sub-Module Model Serial Hw Status
1 Policy Feature Card WS-F6K-PFC SAL0501FVDV 2.0 Ok
1 Cat6k MSFC 2 daughterboard WS-F6K-MSFC2 SAL0551FG7W 2.0 Ok
2 Policy Feature Card WS-F6K-PFC SAL0603GU0U 2.0 Ok
2 Cat6k MSFC 2 daughterboard WS-F6K-MSFC2 SAL0603GUQC 2.0 Ok
Best Regards,
415
