Community Member
Catalyst 6509 FlexWAN problem & redundant SupEng different bootvar problem
1. I have a Catalyst 6509 with FlexWAN & ATM OC3 module. Last week this switch reloaded. All configuration back exceptd ATM module configuration. The ATM module configuration was exist at "show start", but not exist at "show runn". I copy ATM module configuration from startup-config to running-config, It work again. Can you please help to identify the problem?
2. Another strange sympton is when execute "show bootvar", the two supervisor engine have different parameter. Even I change "boot system" & "config-register" again, the boot parameter between two supervisor engine still different. Please also gove me some help to solve this problem.
Best Regards,
1 REPLY
Community Member
Re: Catalyst 6509 FlexWAN problem & redundant SupEng different b
Can anyone help? Best Regards,
579
