Webcast-Catalyst9k
Catalyst 6509 module temperature
The following is my Catalyat 6509 temperature information :
For module 4 ( WS-X6716-10GE ), the inlet temperature is higher than outlet temperature. Please help to mention me why the inlet temperature is higher than outlet temperature? ( For the other module, the inlet temperature is lower than outlet temperature. )
Best Regards,
  VTT 1 outlet temperature: 25C
  VTT 2 outlet temperature: 24C
  VTT 3 outlet temperature: 32C
  module 1 outlet temperature: 30C
  module 1 inlet temperature: 27C
  module 1 device-1 temperature: 23C
  module 1 device-2 temperature: 32C
  module 2 outlet temperature: 30C
  module 2 inlet temperature: 26C
  module 2 device-1 temperature: 23C
  module 2 device-2 temperature: 30C
  module 4 outlet temperature: 38C
  module 4 inlet temperature: 43C
  module 4 asic-1 temperature: 47C
  module 4 asic-2 temperature: 52C
  module 4 EARL outlet temperature: 35C
  module 4 EARL inlet temperature: 31C
  module 5 outlet temperature: 29C
  module 5 inlet temperature: 23C
  module 5 device-1 temperature: 32C
  module 5 device-2 temperature: 34C
  module 5 asic-1 temperature: 23C
  module 5 asic-2 temperature: 24C
  module 5 asic-3 temperature: 23C
  module 5 asic-4 temperature: 23C
  module 5 asic-5 temperature: 24C
  module 5 asic-6 temperature: 23C
  module 5 RP outlet temperature: 26C
  module 5 RP inlet temperature: 27C
  module 5 EARL outlet temperature: 32C
  module 5 EARL inlet temperature: 22C   VTT 1 outlet temperature: 25C
I checked the other Catalyst 6509 with WS-X6716-10GE installed. It have the same issue. Is there anyone have the same issue? ( the inlet temperature is higher than outlet temperature )
Best Regards,
Jackson Ku
Hi Jackson,
1. could you check if the airflow and cooling requirements are appropriate in the room where the switches are located?
2. May i know the Chassis model?
3. is the AC working fine? Is there anything blocking the airflow in the switch?
generally this would happen due to airflow blocking in the switch. moreover, 43 is not so alarming. i would concern about this if it keeps increasing.
A : The airflow and cooling requirements was ok.
A : WS-C6509-E
A : the AC working fine and nothing blocking the airflow
My question is why the inlet temperature is higher than outlet temperature at module 4 ( WS-X6716-10GE ) only? For the other module, the inlet temperature is lower than outlet temperature.
Best Regards,
Jackson Ku
368
