Catalyst 6509 Vlan speed issue
Hi Guys,
I'm new here, and have a question to get things rolling:
I recently setup a new user and managment vlan on my network which has been up until this point running all on vlan 1. The problem is I cannot download data at over 9mB/sec from an end device, uploading on this vlan is fine, up to 30mB/sec. At first I thought it was a limitation of a new 3750 I was using (maybe fiber issue), but after configuring a gigabit port directly on our 6509 core to this new vlan the same issue exists. I will note that devices on vlan 1 do not have this problem. I am kind of stumped here, the ports are connected at full duplex gig. The following is my vlan configuration on the 6509 core switch ( I have removed addressing from my paste, sorry) and a trunk port used for my access switch. Any help or direction is appreciated:
vlan 500
name Managment-Test
vlan 503
name User-Test
interface Vlan500
description Managment - Test
ip address *.*.*.78 255.255.255.240
no ip redirects
no ip proxy-arp
load-interval 30
interface Vlan503
description Access -Test
ip address *.*.*.254 255.255.255.0
ip helper-address *.*.*.*
no ip proxy-arp
load-interval 30
nterface GigabitEthernet7/22
no ip address
load-interval 30
udld port aggressive
switchport
switchport trunk native vlan 500
switchport trunk allowed vlan 1,500,503
switchport mode trunk
storm-control broadcast level 10.00
Re: Catalyst 6509 Vlan speed issue
Any ideas here guys?
Hall of Fame Super Bronze
Can you remove the storm-control on the trunk port and try again ?
What are the 2 hosts you are trying to upload / download btwn connected to? Are they both connected directly to the 6509? Please do a "sh interface x/x" for the two hosts and post that info.
Jay Killion, CCIE #17873
Okay, to make this easier I put a port directly on the core into this new vlan i'm having troubles with (to rule out a configuration problem on my access switch/physical connection problem). The same problems exsists, i'm downloading/uploading from a laptop to a file server, both are connected to the core. My laptop is on the new vlan (503), and the fileserver is on vlan 1.
There is no problem if I connect my end device to a port thats on vlan 1. Also I have tried changing my source server and my laptop to a desktop, same issue.
File Server: Gi6/9 connected 1 a-full a-1000 10/100/1000BaseT
sh run int:
interface GigabitEthernet6/9
no ip address
switchport
end
sh int:
GigabitEthernet6/9 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0015.f9c8.d938 (bia 0015.f9c8.d938)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 3/255, rxload 3/255
Full-duplex, 1000Mb/s
input flow-control is off, output flow-control is off
Clock mode is auto
Last input never, output 00:00:58, output hang never
Last clearing of "show interface" counters 3d18h
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 12523000 bits/sec, 1765 packets/sec
5 minute output rate 11969000 bits/sec, 1767 packets/sec
1479157389 packets input, 2162879403953 bytes, 0 no buffer
Received 18120 broadcasts, 0 runts, 0 giants, 0 throttles
543422299 packets output, 70009375192 bytes, 0 underruns
0 lost carrier, 0 no carrier
Laptop:
sh run int: Gi6/45 connected 503 full 1000 10/100/1000BaseT
nterface GigabitEthernet6/45
no ip address
load-interval 30
speed 1000
duplex full
no snmp trap link-status
switchport
switchport access vlan 503
switchport mode access
no cdp enable
spanning-tree portfast
end
sh int:
GigabitEthernet6/45 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0015.f9c8.d95c (bia 0015.f9c8.d95c)
input flow-control is off, output flow-control is on
Clock mode is auto
Last input never, output 6d23h, output hang never
30 second input rate 1296000 bits/sec, 219 packets/sec
30 second output rate 2774000 bits/sec, 284 packets/sec
371026 packets input, 372652101 bytes, 0 no buffer
Received 7 broadcasts, 0 runts, 0 giants, 0 throttles
374292 packets output, 372852419 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Fun issue ;)
I was expecting to see some sort of duplex mismatch...hmmmmm...Ok, lets narrow down the problem. What happens if you move the server to Vlan 503 w/ the laptop? Do you still have speed issues or is it only inter-vlan transfers?
Unfortunately I can't disconnect the file server, its in production.
I just added another desktop to this vlan on the core, transfers seem fine on the same vlan, 35mB/s.
....this one has me stumped
Ok, next test. Move the desktop over the vlan 1 and try the transfer one more time. After that we'll have a solid baseline to see if it is just intervlan routing that's having a problem.
Yup, desktop and laptop on vlan 1 can transfer just fine, 35mB/s both ways..
Check for Spanning-Tree, if the STP Root for Vlan 1 is different than the STP Root for Vlan 503, the traffic will traverse the trunk.
I see the trunk has a storm-control value for broadcast, perhaps the download you are performing is seeing as broadcast traffic by the port.
As I suggested before, please remove the storm-control from the trunk and try again.
I should have mentioned, I removed the storm control values.
Here is the stp root information:
Root Hello Max Fwd
Vlan Root ID Cost Time Age Dly Root Port
VLAN0001 32768 000d.54a9.e960 4 2 20 15 Gi6/48
VLAN0500 32768 0015.c714.35f4 0 2 20 15
VLAN0503 32768 0015.c714.35f7 0 2 20 15
As suspected, Vlan1 STP Root is different from STP Root from Vlan 500 and 503.
Vlan1 STP Root is being learned via G6/48.
Can you provide the STP information from that switch ?
You can also alter the STP configuration to mirror Vlan1's.
uh oh..
The device plugged into 6/48 is an unmanaged 3com switch (used for test devices in the lab office)....
Change the priority for all Vlans to 0 on the 6509. This way, it will become the STP root for all Vlans.
Is changing this priority on vlan 1 going to bring the vlan down for a bit, just worried because their is currently about 300 users connected to this vlan....
STP will re-converge so it may be a small disruption in the traffic flow. It's safer to do it after-hours.
Well, I made this change from home after hours last night. Came in this morning to test, same thing..
I thought for sure this problem was going to be solved after noticing my stp wasn't configured properly.
Whats next?
Hi EdisonOrtiz,
Any direction on what to check next on this situation?
Let's see the show spantree output once again.
sh spanning-tree root
Root Hello Max Fwd
VLAN0001 0 0015.c714.3401 0 2 20 15
VLAN0500 0 0015.c714.35f4 0 2 20 15
VLAN0503 0 0015.c714.35f7 0 2 20 15
sh spanning-tree summary
Switch is in pvst mode
Root bridge for: VLAN0001, VLAN0500, VLAN0503
EtherChannel misconfig guard is enabled
Extended system ID is disabled
Portfast Default is enabled
PortFast BPDU Guard Default is disabled
Portfast BPDU Filter Default is disabled
Loopguard Default is disabled
UplinkFast is disabled
BackboneFast is disabled
Pathcost method used is short
Name Blocking Listening Learning Forwarding STP Active
VLAN0001 1 0 0 181 182
VLAN0500 1 0 0 9 10
VLAN0503 1 0 0 9 10
3 vlans 3 0 0 199 202
STP looks fine now, let's see a show ip route.
Gateway of last resort is *.*.160.1 to network 0.0.0.0
*.*.0.0/21 is subnetted, 1 subnets
C *.*.160.0 is directly connected, Vlan1
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.217.159.64/28 is directly connected, Vlan500
C 10.217.128.0/24 is directly connected, Vlan503
S* 0.0.0.0/0 [1/0] via *.*.160.1
Looks fine, running out of ideas. Can we see a sanitized show-tech from this switch ? You can also proceed and start a packet trace with an analyzer and see if you see anything out of the ordinary.
Run two traces, one while copying to/from the same VLAN and another while copying to/from the different VLANs.
Here's the tech. I'll have to grab an analyzer somewhere, haven't used one in a few years.
Appreciate the help so far.
Sorry, I see nothing wrong. What kind of application are you using to transfer the files ?
Would you mind using another protocol such as http or ftp and see if you can duplicate the speed issue ?
I've been using http, ftp and rpc traffic, I just did an ftp test, here are the results:
vlan1 device -> vlan 503 device
Transferred 1 file totaling 2.60 GB in 4 minutes 43 seconds (9.41 MB/s)
vlan 503 device -> vlan 1 device
Transferred 1 file totaling 2.60 GB in 1 minute 45 seconds (25.72 MB/s)
I don't know what else to suggest. I believe the only thing left to do, open a TAC case with Cisco.
Yup, guess so, gotta bite the bullet.
I'll post what happens with them.
Thanks for going through everything else with me, learning experience.
Before you open the case ensure that cef is enabled, you may also want to try "ip cef distributed" from global config mode.
Verify cef with: "show ip cef"
Verify cef on an interface with: "show ip int vlan x | include cef"
When I do an sh ip int vlan 503 | include cef
I get nothing.......
243
