06-27-2007 05:19 PM - edited 03-05-2019 05:00 PM
Hi Guys,
I'm new here, and have a question to get things rolling:
I recently setup a new user and managment vlan on my network which has been up until this point running all on vlan 1. The problem is I cannot download data at over 9mB/sec from an end device, uploading on this vlan is fine, up to 30mB/sec. At first I thought it was a limitation of a new 3750 I was using (maybe fiber issue), but after configuring a gigabit port directly on our 6509 core to this new vlan the same issue exists. I will note that devices on vlan 1 do not have this problem. I am kind of stumped here, the ports are connected at full duplex gig. The following is my vlan configuration on the 6509 core switch ( I have removed addressing from my paste, sorry) and a trunk port used for my access switch. Any help or direction is appreciated:
vlan 500
name Managment-Test
vlan 503
name User-Test
interface Vlan500
description Managment - Test
ip address *.*.*.78 255.255.255.240
no ip redirects
no ip proxy-arp
load-interval 30
interface Vlan503
description Access -Test
ip address *.*.*.254 255.255.255.0
ip helper-address *.*.*.*
no ip proxy-arp
load-interval 30
nterface GigabitEthernet7/22
no ip address
load-interval 30
udld port aggressive
switchport
switchport trunk native vlan 500
switchport trunk allowed vlan 1,500,503
switchport mode trunk
storm-control broadcast level 10.00
07-03-2007 01:56 PM
STP will re-converge so it may be a small disruption in the traffic flow. It's safer to do it after-hours.
07-04-2007 04:17 AM
Well, I made this change from home after hours last night. Came in this morning to test, same thing..
I thought for sure this problem was going to be solved after noticing my stp wasn't configured properly.
Whats next?
07-05-2007 09:02 AM
Hi EdisonOrtiz,
Any direction on what to check next on this situation?
07-05-2007 09:33 AM
Let's see the show spantree output once again.
07-05-2007 09:39 AM
sh spanning-tree root
Root Hello Max Fwd
Vlan Root ID Cost Time Age Dly Root Port
VLAN0001 0 0015.c714.3401 0 2 20 15
VLAN0500 0 0015.c714.35f4 0 2 20 15
VLAN0503 0 0015.c714.35f7 0 2 20 15
sh spanning-tree summary
Switch is in pvst mode
Root bridge for: VLAN0001, VLAN0500, VLAN0503
EtherChannel misconfig guard is enabled
Extended system ID is disabled
Portfast Default is enabled
PortFast BPDU Guard Default is disabled
Portfast BPDU Filter Default is disabled
Loopguard Default is disabled
UplinkFast is disabled
BackboneFast is disabled
Pathcost method used is short
Name Blocking Listening Learning Forwarding STP Active
VLAN0001 1 0 0 181 182
VLAN0500 1 0 0 9 10
VLAN0503 1 0 0 9 10
3 vlans 3 0 0 199 202
07-05-2007 09:42 AM
STP looks fine now, let's see a show ip route.
07-05-2007 09:45 AM
Gateway of last resort is *.*.160.1 to network 0.0.0.0
*.*.0.0/21 is subnetted, 1 subnets
C *.*.160.0 is directly connected, Vlan1
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.217.159.64/28 is directly connected, Vlan500
C 10.217.128.0/24 is directly connected, Vlan503
S* 0.0.0.0/0 [1/0] via *.*.160.1
07-05-2007 09:49 AM
Looks fine, running out of ideas. Can we see a sanitized show-tech from this switch ? You can also proceed and start a packet trace with an analyzer and see if you see anything out of the ordinary.
Run two traces, one while copying to/from the same VLAN and another while copying to/from the different VLANs.
07-05-2007 10:07 AM
07-05-2007 12:41 PM
Sorry, I see nothing wrong. What kind of application are you using to transfer the files ?
Would you mind using another protocol such as http or ftp and see if you can duplicate the speed issue ?
07-06-2007 06:34 AM
I've been using http, ftp and rpc traffic, I just did an ftp test, here are the results:
vlan1 device -> vlan 503 device
Transferred 1 file totaling 2.60 GB in 4 minutes 43 seconds (9.41 MB/s)
vlan 503 device -> vlan 1 device
Transferred 1 file totaling 2.60 GB in 1 minute 45 seconds (25.72 MB/s)
07-06-2007 06:51 AM
I don't know what else to suggest. I believe the only thing left to do, open a TAC case with Cisco.
07-06-2007 06:59 AM
Yup, guess so, gotta bite the bullet.
I'll post what happens with them.
Thanks for going through everything else with me, learning experience.
07-06-2007 12:26 PM
Before you open the case ensure that cef is enabled, you may also want to try "ip cef distributed" from global config mode.
Verify cef with: "show ip cef"
Verify cef on an interface with: "show ip int vlan x | include cef"
07-08-2007 03:12 PM
When I do an sh ip int vlan 503 | include cef
I get nothing.......
