Catalyst 6509 - VSS - standby reloads unexpected
We have 2 Catalyst 6509 running in VSS mode. After running for about 4 months without problems now the standby switch (switch no. 1) reloads unexpected.
One suspicion is a relation to a power failure some days ago another suspicion is after a configuration change.
(some where I found an issue of a timeout during the config sync with a large config file)
IOS = (s72033_rp-ADVENTERPRISEK9-M), Version 12.2(33)SXI1
Are there any ideas why these reloads happen?
And what do the messages "vs_get_pslot_switch_id():vslot error" mean ?
here's the logging from this:
Jan  5 08:53:06 vssrout1 609705: Jan  5 08:53:05: %PARSER-6-EXPOSEDLOCKACQUIRED: Exclusive configuration lock acquired by user 'unknown' from terminal '1'  -Process= "SSH Process", ipl= 0, pid= 176
Jan  5 08:53:16 vssrout1 609706: Jan  5 08:53:15: %PARSER-5-CFGLOG_LOGGEDCMD: User:admin  logged command:ip access-list extended 100
Jan  5 08:53:42 vssrout1 609709: Jan  5 08:53:42: %PARSER-5-CFGLOG_LOGGEDCMD: User:admin  logged command:1020 permit ip 10.10.0.0 0.0.255.255 any log-input
Jan  5 08:53:43 vssrout1 609710: Jan  5 08:53:42: Config Sync: Line-by-Line sync verifying failure on command:   1020 permit ip 10.10.0.0 0.0.255.255 any log-input due to parser return error
Jan  5 08:53:45 vssrout1 609711: Jan  5 08:53:43: %RF-SW2_SP-5-RF_RELOAD: Peer reload. Reason: Proxy request to reload peer
Jan  5 08:53:45 vssrout1 609712: Jan  5 08:53:43: %SYS-SW1_SPSTBY-5-RELOAD: Reload requested - From Active Switch (Reload peer unit).
Jan  5 08:53:45 vssrout1 609713: Jan  5 08:53:44: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/5/4, changed state to down
Jan  5 08:53:45 vssrout1 609714: Jan  5 08:53:44: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/5/4, changed state to down
Jan  5 08:53:45 vssrout1 609715: Jan  5 08:53:45: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/5/4, changed state to down
Jan  5 08:53:45 vssrout1 609716: Jan  5 08:53:45: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/1/1, changed state to down
Jan  5 08:53:45 vssrout1 609717: Jan  5 08:53:45: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel200, changed state to down
Jan  5 08:53:45 vssrout1 609718: Jan  5 08:53:45: %LINK-3-UPDOWN: Interface Port-channel200, changed state to down
Jan  5 08:53:45 vssrout1 609719: Jan  5 08:53:45: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/1/1, changed state to down
Jan  5 08:53:45 vssrout1 609720: Jan  5 08:53:45: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/5/4, changed state to down
Jan  5 08:53:45 vssrout1 609721: Jan  5 08:53:44: %VSLP-SW2_SP-3-VSLP_LMP_FAIL_REASON: Te2/5/4: Disabled by Peer Reload Request
Jan  5 08:53:45 vssrout1 609722: Jan  5 08:53:44: %VSL-SW2_SP-5-VSL_CNTRL_LINK:  New VSL Control Link Te2/1/1
Jan  5 08:53:45 vssrout1 609723: Jan  5 08:53:44: %VSLP-SW2_SP-3-VSLP_LMP_FAIL_REASON: Te2/1/1: Disabled by Peer Reload Request
Jan  5 08:53:45 vssrout1 609724: Jan  5 08:53:44: %VSLP-SW2_SP-2-VSL_DOWN:   Last VSL interface Te2/1/1 went down
Jan  5 08:53:45 vssrout1 609725: Jan  5 08:53:44: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/5/4, changed state to down
Jan  5 08:53:45 vssrout1 609726: Jan  5 08:53:44: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/5/4, changed state to down
Jan  5 08:53:45 vssrout1 609727: Jan  5 08:53:44: %VSLP-SW2_SP-2-VSL_DOWN:   All VSL links went down while switch is in ACTIVE role
Jan  5 08:53:45 vssrout1 609728: Jan  5 08:53:44: %LINK-SW2_SP-3-UPDOWN: Interface TenGigabitEthernet2/5/4, changed state to down
Jan  5 08:53:45 vssrout1 609729: Jan  5 08:53:44: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/1/1, changed state to down
Jan  5 08:53:45 vssrout1 609730: Jan  5 08:53:44: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface Port-channel200, changed state to down
Jan  5 08:53:45 vssrout1 609731: Jan  5 08:53:45: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel100, changed state to down
Jan  5 08:53:45 vssrout1 609732: Jan  5 08:53:45: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel90, changed state to down
Jan  5 08:53:45 vssrout1 609733: Jan  5 08:53:45: %LINK-3-UPDOWN: Interface Port-channel100, changed state to down
Jan  5 08:53:45 vssrout1 609734: Jan  5 08:53:45: %LINK-3-UPDOWN: Interface Port-channel90, changed state to down
Jan  5 08:53:45 vssrout1 609735: Jan  5 08:53:45: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/1, changed state to down
Jan  5 08:53:45 vssrout1 609736: Jan  5 08:53:45: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/4, changed state to down
Jan  5 08:53:46 vssrout1 609737: Jan  5 08:53:45: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/1, changed state to down
Jan  5 08:53:46 vssrout1 609738: Jan  5 08:53:45: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/4, changed state to down
Jan  5 08:53:46 vssrout1 609739: Jan  5 08:53:46: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/1, changed state to down
Jan  5 08:53:46 vssrout1 609740: Jan  5 08:53:46: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/2, changed state to down
Jan  5 08:53:46 vssrout1 609741: Jan  5 08:53:46: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/3, changed state to down
Jan  5 08:53:46 vssrout1 609742: Jan  5 08:53:46: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/4, changed state to down
Jan  5 08:53:46 vssrout1 609743: Jan  5 08:53:46: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/5, changed state to down
Jan  5 08:53:46 vssrout1 609744: Jan  5 08:53:46: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/6, changed state to down
Jan  5 08:53:46 vssrout1 609745: Jan  5 08:53:46: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/7, changed state to down
Jan  5 08:53:46 vssrout1 609746: Jan  5 08:53:46: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/8, changed state to down
Jan  5 08:53:46 vssrout1 609747: Jan  5 08:53:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/1, changed state to down
Jan  5 08:53:46 vssrout1 609748: Jan  5 08:53:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/2, changed state to down
Jan  5 08:53:46 vssrout1 609749: Jan  5 08:53:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/3, changed state to down
Jan  5 08:53:46 vssrout1 609750: Jan  5 08:53:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/4, changed state to down
Jan  5 08:53:46 vssrout1 609751: Jan  5 08:53:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/5, changed state to down
Jan  5 08:53:46 vssrout1 609752: Jan  5 08:53:46: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/11, changed state to down
Jan  5 08:53:46 vssrout1 609753: Jan  5 08:53:46: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/12, changed state to down
Jan  5 08:53:46 vssrout1 609754: Jan  5 08:53:46: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/13, changed state to down
Jan  5 08:53:46 vssrout1 609755: Jan  5 08:53:46: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/14, changed state to down
Jan  5 08:53:46 vssrout1 609756: Jan  5 08:53:46: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/15, changed state to down
Jan  5 08:53:46 vssrout1 609757: Jan  5 08:53:46: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/16, changed state to down
Jan  5 08:53:46 vssrout1 609758: Jan  5 08:53:46: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/17, changed state to down
Jan  5 08:53:46 vssrout1 609759: Jan  5 08:53:46: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/18, changed state to down
Jan  5 08:53:46 vssrout1 609760: Jan  5 08:53:46: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/19, changed state to down
Jan  5 08:53:46 vssrout1 609761: Jan  5 08:53:46: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/20, changed state to down
Jan  5 08:53:46 vssrout1 609762: Jan  5 08:53:46: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/21, changed state to down
Jan  5 08:53:46 vssrout1 609763: Jan  5 08:53:46: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/22, changed state to down
Jan  5 08:53:46 vssrout1 609764: Jan  5 08:53:46: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/23, changed state to down
Jan  5 08:53:46 vssrout1 609765: Jan  5 08:53:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/6, changed state to down
Jan  5 08:53:46 vssrout1 609766: Jan  5 08:53:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/7, changed state to down
Jan  5 08:53:46 vssrout1 609767: Jan  5 08:53:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/8, changed state to down
Jan  5 08:53:46 vssrout1 609768: Jan  5 08:53:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/11, changed state to down
Jan  5 08:53:46 vssrout1 609769: Jan  5 08:53:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/12, changed state to down
Jan  5 08:53:46 vssrout1 609770: Jan  5 08:53:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/13, changed state to down
Jan  5 08:53:46 vssrout1 609771: Jan  5 08:53:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/14, changed state to down
Jan  5 08:53:46 vssrout1 609772: Jan  5 08:53:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/15, changed state to down
Jan  5 08:53:46 vssrout1 609773: Jan  5 08:53:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/16, changed state to down
Jan  5 08:53:46 vssrout1 609774: Jan  5 08:53:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/17, changed state to down
Jan  5 08:53:46 vssrout1 609775: Jan  5 08:53:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/18, changed state to down
Jan  5 08:53:46 vssrout1 609776: Jan  5 08:53:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/19, changed state to down
Jan  5 08:53:46 vssrout1 609777: Jan  5 08:53:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/20, changed state to down
Jan  5 08:53:46 vssrout1 609778: Jan  5 08:53:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/21, changed state to down
Jan  5 08:53:46 vssrout1 609779: Jan  5 08:53:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/22, changed state to down
Jan  5 08:53:46 vssrout1 609780: Jan  5 08:53:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/23, changed state to down
Jan  5 08:53:47 vssrout1 609781: Jan  5 08:53:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel585, changed state to down
Jan  5 08:53:47 vssrout1 609782: Jan  5 08:53:46: %LINK-5-CHANGED: Interface GigabitEthernet1/9/1, changed state to administratively down
Jan  5 08:53:47 vssrout1 609783: Jan  5 08:53:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9/1, changed state to down
Jan  5 08:53:47 vssrout1 609784: Jan  5 08:53:47: %LINK-5-CHANGED: Interface GigabitEthernet1/9/2, changed state to administratively down
Jan  5 08:53:47 vssrout1 609785: Jan  5 08:53:47: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9/2, changed state to down
Jan  5 08:53:47 vssrout1 609786: Jan  5 08:53:47: %LINK-5-CHANGED: Interface GigabitEthernet1/9/3, changed state to administratively down
Jan  5 08:53:47 vssrout1 609787: Jan  5 08:53:47: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9/3, changed state to down
Jan  5 08:53:47 vssrout1 609788: Jan  5 08:53:47: %LINK-5-CHANGED: Interface GigabitEthernet1/9/4, changed state to administratively down
Jan  5 08:53:47 vssrout1 609789: Jan  5 08:53:47: %LINK-5-CHANGED: Interface GigabitEthernet1/9/5, changed state to administratively down
Jan  5 08:53:47 vssrout1 609790: Jan  5 08:53:47: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9/4, changed state to down
Jan  5 08:53:47 vssrout1 609791: Jan  5 08:53:47: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9/5, changed state to down
Jan  5 08:53:47 vssrout1 609792: Jan  5 08:53:47: %LINK-5-CHANGED: Interface GigabitEthernet1/9/6, changed state to administratively down
Jan  5 08:53:47 vssrout1 609793: Jan  5 08:53:47: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9/6, changed state to down
Jan  5 08:53:47 vssrout1 609794: Jan  5 08:53:44: %LINK-SW2_SP-3-UPDOWN: Interface Port-channel200, changed state to down
Jan  5 08:53:47 vssrout1 609795: Jan  5 08:53:44: %LINK-SW2_SP-3-UPDOWN: Interface TenGigabitEthernet2/1/1, changed state to down
Jan  5 08:53:47 vssrout1 609796: Jan  5 08:53:45: %LINK-SW2_SP-3-UPDOWN: Interface TenGigabitEthernet1/5/4, changed state to down
Jan  5 08:53:47 vssrout1 609797: Jan  5 08:53:45: SW2_SP:  Switch 1 Physical Slot 5 - Module Type LINE_CARD  removed
Jan  5 08:53:47 vssrout1 609798: Jan  5 08:53:45: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface Port-channel100, changed state to down
Jan  5 08:53:47 vssrout1 609799: Jan  5 08:53:45: %LINK-SW2_SP-3-UPDOWN: Interface TenGigabitEthernet1/1/1, changed state to down
Jan  5 08:53:47 vssrout1 609800: Jan  5 08:53:45: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface Port-channel90, changed state to down
Jan  5 08:53:47 vssrout1 609801: Jan  5 08:53:45: %LINK-SW2_SP-3-UPDOWN: Interface Port-channel100, changed state to down
Jan  5 08:53:47 vssrout1 609802: Jan  5 08:53:45: %LINK-SW2_SP-3-UPDOWN: Interface TenGigabitEthernet1/1/4, changed state to down
Jan  5 08:53:47 vssrout1 609803: Jan  5 08:53:45: %LINK-SW2_SP-3-UPDOWN: Interface Port-channel90, changed state to down
Jan  5 08:53:47 vssrout1 609804: Jan  5 08:53:45: %LINK-SW2_SP-3-UPDOWN: Interface TenGigabitEthernet1/1/8, changed state to down
Jan  5 08:53:47 vssrout1 609805: Jan  5 08:53:45: %PFREDUN-SW2_SP-6-ACTIVE: Standby processor removed or reloaded, changing to Simplex mode
Jan  5 08:53:47 vssrout1 609806: Jan  5 08:53:45: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/1, changed state to down
Jan  5 08:53:47 vssrout1 609807: Jan  5 08:53:45: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/4, changed state to down
Jan  5 08:53:47 vssrout1 609808: Jan  5 08:53:45: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/8, changed state to down
Jan  5 08:53:47 vssrout1 609809: Jan  5 08:53:45: SW2_SP:  Switch 1 Physical Slot 1 - Module Type LINE_CARD  removed
Jan  5 08:53:47 vssrout1 609810: Jan  5 08:53:45: %LINK-SW2_SP-3-UPDOWN: Interface TenGigabitEthernet1/2/8, changed state to down
Jan  5 08:53:47 vssrout1 609811: Jan  5 08:53:45: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/2/8, changed state to down
Jan  5 08:53:47 vssrout1 609812: Jan  5 08:53:45: SW2_SP:  Switch 1 Physical Slot 2 - Module Type LINE_CARD  removed
Jan  5 08:53:47 vssrout1 609813: Jan  5 08:53:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/1, changed state to down
Jan  5 08:53:47 vssrout1 609814: Jan  5 08:53:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/2, changed state to down
Jan  5 08:53:47 vssrout1 609815: Jan  5 08:53:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/3, changed state to down
Jan  5 08:53:47 vssrout1 609816: Jan  5 08:53:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/4, changed state to down
Jan  5 08:53:47 vssrout1 609817: Jan  5 08:53:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/5, changed state to down
Jan  5 08:53:47 vssrout1 609818: Jan  5 08:53:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/6, changed state to down
Jan  5 08:53:47 vssrout1 609819: Jan  5 08:53:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/7, changed state to down
Jan  5 08:53:47 vssrout1 609820: Jan  5 08:53:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/8, changed state to down
Jan  5 08:53:47 vssrout1 609821: Jan  5 08:53:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/11, changed state to down
Jan  5 08:53:47 vssrout1 609822: Jan  5 08:53:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/12, changed state to down
Jan  5 08:53:47 vssrout1 609823: Jan  5 08:53:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/13, changed state to down
Jan  5 08:53:47 vssrout1 609824: Jan  5 08:53:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/14, changed state to down
Jan  5 08:53:47 vssrout1 609825: Jan  5 08:53:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/15, changed state to down
Jan  5 08:53:47 vssrout1 609826: Jan  5 08:53:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/16, changed state to down
Jan  5 08:53:47 vssrout1 609827: Jan  5 08:53:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/17, changed state to down
Jan  5 08:53:47 vssrout1 609828: Jan  5 08:53:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/18, changed state to down
Jan  5 08:53:47 vssrout1 609829: Jan  5 08:53:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/19, changed state to down
Jan  5 08:53:47 vssrout1 609830: Jan  5 08:53:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/20, changed state to down
Jan  5 08:53:47 vssrout1 609831: Jan  5 08:53:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/21, changed state to down
Jan  5 08:53:47 vssrout1 609832: Jan  5 08:53:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/22, changed state to down
Jan  5 08:53:47 vssrout1 609833: Jan  5 08:53:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/23, changed state to down
Jan  5 08:53:47 vssrout1 609834: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/1, changed state to down
Jan  5 08:53:47 vssrout1 609835: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/2, changed state to down
Jan  5 08:53:47 vssrout1 609836: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/3, changed state to down
Jan  5 08:53:47 vssrout1 609837: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/4, changed state to down
Jan  5 08:53:47 vssrout1 609838: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/5, changed state to down
Jan  5 08:53:47 vssrout1 609839: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/6, changed state to down
Jan  5 08:53:47 vssrout1 609840: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/7, changed state to down
Jan  5 08:53:47 vssrout1 609841: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/8, changed state to down
Jan  5 08:53:47 vssrout1 609842: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/11, changed state to down
Jan  5 08:53:47 vssrout1 609843: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/12, changed state to down
Jan  5 08:53:47 vssrout1 609844: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/13, changed state to down
Jan  5 08:53:47 vssrout1 609845: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/14, changed state to down
Jan  5 08:53:47 vssrout1 609846: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/15, changed state to down
Jan  5 08:53:47 vssrout1 609847: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/16, changed state to down
Jan  5 08:53:47 vssrout1 609848: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/17, changed state to down
Jan  5 08:53:47 vssrout1 609849: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/18, changed state to down
Jan  5 08:53:47 vssrout1 609850: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/19, changed state to down
Jan  5 08:53:47 vssrout1 609851: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/20, changed state to down
Jan  5 08:53:47 vssrout1 609852: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/21, changed state to down
Jan  5 08:53:47 vssrout1 609853: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/22, changed state to down
Jan  5 08:53:47 vssrout1 609854: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/23, changed state to down
Jan  5 08:53:47 vssrout1 609855: Jan  5 08:53:46: SW2_SP:  Switch 1 Physical Slot 4 - Module Type LINE_CARD  removed
Jan  5 08:53:47 vssrout1 609856: Jan  5 08:53:46: %LINK-SW2_SP-5-CHANGED: Interface GigabitEthernet1/9/1, changed state to administratively down
Jan  5 08:53:47 vssrout1 609857: Jan  5 08:53:46: %LINK-SW2_SP-5-CHANGED: Interface GigabitEthernet1/9/2, changed state to administratively down
Jan  5 08:53:47 vssrout1 609858: Jan  5 08:53:46: %LINK-SW2_SP-5-CHANGED: Interface GigabitEthernet1/9/3, changed state to administratively down
Jan  5 08:53:47 vssrout1 609859: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface Port-channel585, changed state to down
Jan  5 08:53:47 vssrout1 609860: Jan  5 08:53:46: %LINK-SW2_SP-5-CHANGED: Interface GigabitEthernet1/9/4, changed state to administratively down
Jan  5 08:53:47 vssrout1 609861: Jan  5 08:53:46: %LINK-SW2_SP-5-CHANGED: Interface GigabitEthernet1/9/5, changed state to administratively down
Jan  5 08:53:47 vssrout1 609862: Jan  5 08:53:46: %LINK-SW2_SP-5-CHANGED: Interface GigabitEthernet1/9/6, changed state to administratively down
Jan  5 08:53:47 vssrout1 609863: Jan  5 08:53:46: %LINK-SW2_SP-3-UPDOWN: Interface Port-channel585, changed state to down
Jan  5 08:53:47 vssrout1 609864: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9/1, changed state to down
Jan  5 08:53:47 vssrout1 609865: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9/2, changed state to down
Jan  5 08:53:47 vssrout1 609866: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9/3, changed state to down
Jan  5 08:53:47 vssrout1 609867: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9/4, changed state to down
Jan  5 08:53:47 vssrout1 609868: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9/5, changed state to down
Jan  5 08:53:47 vssrout1 609869: Jan  5 08:53:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9/6, changed state to down
Jan  5 08:53:48 vssrout1 609870: Jan  5 08:53:46: %SATVS_IBC-SW2_SP-5-VSL_DOWN_SCP_DROP: VSL inactive - dropping cached SCP packet: (SA/DA:0x4/0x4, SSAP/DSAP:0x27/0x0, OP/SEQ:0x320/0x9EDC, SIG/INFO:0x1/0x502, eSA:0000.0500.0000)
Jan  5 08:53:49 vssrout1 609871: Jan  5 08:53:47: SW2_SP:  Switch 1 Physical Slot 9 - Module Type LINE_CARD  removed
Jan  5 08:53:49 vssrout1 609872:  Jan  5 08:53:47: SW2_SP: remote_bay_ps_remove: couldn't sync the event
Jan  5 08:54:08 vssrout1 609873: Jan  5 08:54:07: %PARSER-5-CFGLOG_LOGGEDCMD: User:admin  logged command:1022 deny ip any any
Jan  5 08:54:13 vssrout1 609874: Jan  5 08:54:12: %PARSER-5-CFGLOG_LOGGEDCMD: User:admin  logged command:no 1019
Jan  5 08:54:16 vssrout1 609894: Jan  5 08:54:15: %PARSER-5-CFGLOG_LOGGEDCMD: User:admin  logged command:no 1021
Jan  5 08:54:43 vssrout1 609937: Jan  5 08:54:42: %PARSER-5-CFGLOG_LOGGEDCMD: User:admin  logged command:1021 permit ip 10.10.0.0 0.0.255.255 any
Jan  5 08:54:47 vssrout1 609957: Jan  5 08:54:46: %PARSER-5-CFGLOG_LOGGEDCMD: User:admin  logged command:no 1020
Jan  5 08:54:55 vssrout1 609958: Jan  5 08:54:55: %SYS-5-CONFIG_I: Configured from console by admin on vty0 (x.x.x.x)
Jan  5 08:54:56 vssrout1 609959: Jan  5 08:54:55: %PARSER-6-EXPOSEDLOCKRELEASED: Exclusive configuration lock released from terminal '1' -Process= "SSH Process", ipl= 0, pid= 176
Jan  5 08:55:21 vssrout1 609961: Jan  5 08:55:20: %PARSER-6-EXPOSEDLOCKACQUIRED: Exclusive configuration lock acquired by user 'unknown' from terminal '1'  -Process= "SSH Process", ipl= 0, pid= 176
Jan  5 08:55:26 vssrout1 609962: Jan  5 08:55:25: %PARSER-5-CFGLOG_LOGGEDCMD: User:admin  logged command:ip access-list extended 100
Jan  5 08:55:38 vssrout1 609963: Jan  5 08:55:37: %PARSER-5-CFGLOG_LOGGEDCMD: User:admin  logged command:1020 permit ip 10.10.0.0 0.0.255.255 any
Jan  5 08:55:41 vssrout1 609964: Jan  5 08:55:40: %PARSER-5-CFGLOG_LOGGEDCMD: User:admin  logged command:no 1021
Jan  5 08:55:53 vssrout1 609965: Jan  5 08:55:52: %PARSER-5-CFGLOG_LOGGEDCMD: User:admin  logged command:1030 deny ip any any
Jan  5 08:56:09 vssrout1 609966: Jan  5 08:56:08: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/5/4, changed state to up
Jan  5 08:56:10 vssrout1 609967: Jan  5 08:56:09: %PARSER-5-CFGLOG_LOGGEDCMD: User:admin  logged command:no 1022
Jan  5 08:56:11 vssrout1 609968: Jan  5 08:56:08: %LINK-SW2_SP-3-UPDOWN: Interface TenGigabitEthernet2/5/4, changed state to up
Jan  5 08:56:26 vssrout1 609969: Jan  5 08:56:26: %PARSER-5-CFGLOG_LOGGEDCMD: User:admin  logged command:1031 deny ip any any log-input
Jan  5 08:56:29 vssrout1 609973: Jan  5 08:56:29: %PARSER-5-CFGLOG_LOGGEDCMD: User:admin  logged command:no 1030
Jan  5 08:56:34 vssrout1 609979: Jan  5 08:56:33: %VSLP-SW2_SP-5-RRP_ROLE_RESOLVED: Role resolved as ACTIVE  by VSLP
Jan  5 08:56:34 vssrout1 609980: Jan  5 08:56:33: %VSL-SW2_SP-5-VSL_CNTRL_LINK:  New VSL Control Link Te2/5/4
Jan  5 08:56:37 vssrout1 609984: Jan  5 08:56:35: %VSLP-SW2_SP-5-VSL_UP:  Ready for control traffic
Jan  5 08:58:27 vssrout1 610097: Jan  5 08:58:25: %PFREDUN-SW2_SP-6-ACTIVE: Standby initializing for SSO mode
Jan  5 08:58:39 vssrout1 610110: Jan  5 08:58:38: %PFINIT-SW2_SP-5-CONFIG_SYNC: Sync'ing the startup configuration to the standby Router.
Jan  5 08:59:22 vssrout1 610155: Jan  5 08:59:20: SW2_SP:  Switch 1 Physical Slot 5 - Module Type LINE_CARD  inserted
Jan  5 08:59:34 vssrout1 610167: Jan  5 08:59:33: %LINK-3-UPDOWN: Interface GigabitEthernet1/5/3, changed state to down
Jan  5 08:59:34 vssrout1 610169: Jan  5 08:59:34: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/5/4, changed state to down
Jan  5 08:59:34 vssrout1 610170: Jan  5 08:59:34: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/5/4, changed state to up
Jan  5 08:59:34 vssrout1 610171: Jan  5 08:59:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/5/4, changed state to up
Jan  5 08:59:34 vssrout1 610172: Jan  5 08:59:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/5/4, changed state to up
Jan  5 08:59:34 vssrout1 610173: Jan  5 08:59:34: %LINK-3-UPDOWN: Interface Port-channel200, changed state to up
Jan  5 08:59:34 vssrout1 610174: Jan  5 08:59:34: %LINK-3-UPDOWN: Interface Port-channel100, changed state to up
Jan  5 08:59:34 vssrout1 610175: Jan  5 08:59:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel200, changed state to up
Jan  5 08:59:34 vssrout1 610176: Jan  5 08:59:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel100, changed state to up
Jan  5 08:59:34 vssrout1 610177: Jan  5 08:59:34: %VSLP-SW2_SP-5-VSL_UP:  Ready for data traffic
Jan  5 08:59:34 vssrout1 610178:  Jan  5 08:59:34: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/5/4, changed state to up
Jan  5 08:59:34 vssrout1 610179: Jan  5 08:59:34: %LINK-SW2_SP-3-UPDOWN: Interface TenGigabitEthernet1/5/4, changed state to up
Jan  5 08:59:34 vssrout1 610180: Jan  5 08:59:34: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/5/4, changed state to up
Jan  5 08:59:35 vssrout1 610181: Jan  5 08:59:34: %LINK-SW2_SP-3-UPDOWN: Interface Port-channel200, changed state to up
Jan  5 08:59:35 vssrout1 610182: Jan  5 08:59:34: %LINK-SW2_SP-3-UPDOWN: Interface Port-channel100, changed state to up
Jan  5 08:59:36 vssrout1 610184: Jan  5 08:59:34: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface Port-channel200, changed state to up
Jan  5 08:59:36 vssrout1 610185: Jan  5 08:59:34: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface Port-channel100, changed state to up
Jan  5 08:59:37 vssrout1 610187: Jan  5 08:59:35: SW2_SP:  Card inserted in Switch_number = 1 ,
Jan  5 08:59:37 vssrout1 610188:                 physical slot 5, interfaces are now online
Jan  5 08:59:49 vssrout1 610201: Jan  5 08:59:49: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 08:59:49 vssrout1 610202: Jan  5 08:59:49: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B4AC 41F2B3E4 41FAE2A0 41AFA348 41B5C7A0 41FE453C 4059755C 4061D0E0 40618570 40618EFC
Jan  5 08:59:49 vssrout1 610203: Jan  5 08:59:49: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 08:59:49 vssrout1 610204: Jan  5 08:59:49: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B514 41F2B3F4 41FAE2A0 41AFA348 41B5C7A0 41FE453C 4059755C 4061D0E0 40618570 40618EFC
Jan  5 08:59:49 vssrout1 610205: Jan  5 08:59:49: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 08:59:49 vssrout1 610206: Jan  5 08:59:49: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B588 41F2B674 41F2B404 41FAE2A0 41AFA348 41B5C7A0 41FE453C 4059755C 4061D0E0 40618570
Jan  5 08:59:49 vssrout1 610207: Jan  5 08:59:49: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 08:59:49 vssrout1 610208: Jan  5 08:59:49: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B830 41F2B414 41FAE2A0 41AFA348 41B5C7A0 41FE453C 4059755C 4061D0E0 40618570 40618EFC
Jan  5 08:59:49 vssrout1 610209: Jan  5 08:59:49: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 08:59:49 vssrout1 610210: Jan  5 08:59:49: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B780 41F2B424 41FAE2A0 41AFA348 41B5C7A0 41FE453C 4059755C 4061D0E0 40618570 40618EFC
Jan  5 08:59:49 vssrout1 610211: Jan  5 08:59:49: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 08:59:49 vssrout1 610212: Jan  5 08:59:49: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B7D8 41F2B434 41FAE2A0 41AFA348 41B5C7A0 41FE453C 4059755C 4061D0E0 40618570 40618EFC
Jan  5 08:59:49 vssrout1 610213: Jan  5 08:59:49: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 08:59:49 vssrout1 610214: Jan  5 08:59:49: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B4AC 41F2B3E4 41FAE2A0 41AFBD28 4059755C 4061D0E0 40618570 40618EFC 42473E68 41FBD7F4
Jan  5 08:59:49 vssrout1 610215: Jan  5 08:59:49: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 08:59:49 vssrout1 610216: Jan  5 08:59:49: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B514 41F2B3F4 41FAE2A0 41AFBD28 4059755C 4061D0E0 40618570 40618EFC 42473E68 41FBD7F4
Jan  5 08:59:49 vssrout1 610217: Jan  5 08:59:49: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 08:59:49 vssrout1 610218: Jan  5 08:59:49: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B588 41F2B674 41F2B404 41FAE2A0 41AFBD28 4059755C 4061D0E0 40618570 40618EFC 42473E68
Jan  5 08:59:49 vssrout1 610219: Jan  5 08:59:49: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 08:59:49 vssrout1 610220: Jan  5 08:59:49: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B830 41F2B414 41FAE2A0 41AFBD28 4059755C 4061D0E0 40618570 40618EFC 42473E68 41FBD7F4
Jan  5 08:59:49 vssrout1 610221: Jan  5 08:59:49: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 08:59:49 vssrout1 610222: Jan  5 08:59:49: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B780 41F2B424 41FAE2A0 41AFBD28 4059755C 4061D0E0 40618570 40618EFC 42473E68 41FBD7F4
Jan  5 08:59:49 vssrout1 610223: Jan  5 08:59:49: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 08:59:49 vssrout1 610224: Jan  5 08:59:49: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B7D8 41F2B434 41FAE2A0 41AFBD28 4059755C 4061D0E0 40618570 40618EFC 42473E68 41FBD7F4
Jan  5 09:00:40 vssrout1 610278: *Jan  5 07:59:05.645: SW1_SPSTBY: SP: Currently running ROMMON from S (Gold) region
Jan  5 09:00:40 vssrout1 610279: Jan  5 07:59:14.685: %C6KPWR-SW1_SPSTBY-4-PSOK: power supply 1 turned on.
Jan  5 09:00:40 vssrout1 610280: Jan  5 07:59:16.722: %FABRIC-SW1_SPSTBY-5-CLEAR_BLOCK: Clear block option is off for the fabric in slot 5.
Jan  5 09:00:40 vssrout1 610281: Jan  5 07:59:16.722: %FABRIC-SW1_SPSTBY-5-FABRIC_MODULE_ACTIVE: The Switch Fabric Module in slot 5 became active.
Jan  5 09:00:40 vssrout1 610282: Jan  5 07:59:17.350: %DIAG-SW1_SPSTBY-6-RUN_MINIMUM: Switch 1 Module 5: Running Minimal Diagnostics...
Jan  5 09:00:40 vssrout1 610283: Jan  5 07:59:17.402: %CONST_DIAG-SW1_SPSTBY-6-DIAG_PORT_SKIPPED: Module 5 port 4 is skipped in TestLoopback due to: the port is used as a VSL link.
Jan  5 09:00:40 vssrout1 610284: Jan  5 07:59:20.800: %CONST_DIAG-SW1_SPSTBY-6-DIAG_PORT_SKIPPED: Module 5 port 4 is skipped in TestChannel due to: the port is used as a VSL link.
Jan  5 09:00:40 vssrout1 610285: Jan  5 07:59:28.629: %DIAG-SW1_SPSTBY-6-DIAG_OK: Switch 1 Module 5: Passed Online Diagnostics
Jan  5 09:00:40 vssrout1 610286: Jan  5 07:59:29.653: %C6KENV-SW1_SPSTBY-4-USE_RED_CLOCK: system is using the redundant clock (clock B).
Jan  5 09:00:40 vssrout1 610287: Jan  5 08:00:35.429: %SYS-SW1_SPSTBY-5-RESTART: System restarted --
Jan  5 09:00:40 vssrout1 610288: Cisco IOS Software, s72033_sp Software (s72033_sp-ADVENTERPRISEK9-M), Version 12.2(33)SXI1, RELEASE SOFTWARE (fc3)
Jan  5 09:00:40 vssrout1 610289: Technical Support: http://www.cisco.com/techsupport
Jan  5 09:00:40 vssrout1 610290: Copyright (c) 1986-2009 by Cisco Systems, Inc.
Jan  5 09:00:40 vssrout1 610291: Compiled Sat 28-Mar-09 10:48 by prod_rel_team
Jan  5 09:00:41 vssrout1 610292: Jan  5 09:00:36: %SYS-SW1_SPSTBY-6-BOOTTIME: Time taken to reboot after reload =  413 seconds
Jan  5 09:00:45 vssrout1 610297: Jan  5 09:00:40: %SYS-SW1_SPSTBY-3-LOGGER_FLUSHED: System was paused for 00:02:13 to ensure console debugging output.
Jan  5 09:00:47 vssrout1 610300: IPC SSO ERROR: Session count execeeded
Jan  5 09:00:56 vssrout1 610310: Jan  5 09:00:55: %HA_CONFIG_SYNC-6-BULK_CFGSYNC_SUCCEED: Bulk Sync succeeded
Jan  5 09:00:56 vssrout1 610311: Jan  5 09:00:55: %PFREDUN-SW1_SPSTBY-6-STANDBY: Ready for SSO mode
Jan  5 09:00:57 vssrout1 610313: Jan  5 09:00:55: %RF-SW2_SP-5-RF_TERMINAL_STATE: Terminal state reached for (SSO)
Jan  5 09:01:00 vssrout1 610318: Jan  5 09:00:59: SW2_SP:  Switch 1 Physical Slot 1 - Module Type LINE_CARD  inserted
Jan  5 09:01:01 vssrout1 610320: Jan  5 09:00:58: %C6KENV-SW1_SPSTBY-4-FANHPMODE: Switch 1 Fan-tray 1 is operating in high power mode
Jan  5 09:01:01 vssrout1 610321: Jan  5 09:01:01: %SYS-5-CONFIG_I: Configured from console by admin on vty0 (x.x.x.x)
Jan  5 09:01:01 vssrout1 610322: Jan  5 09:01:01: %PARSER-6-EXPOSEDLOCKRELEASED: Exclusive configuration lock released from terminal '1' -Process= "SSH Process", ipl= 0, pid= 176
Jan  5 09:01:01 vssrout1 610324: Jan  5 09:01:00: SW2_SP:  Switch 1 Physical Slot 2 - Module Type LINE_CARD  inserted
Jan  5 09:01:01 vssrout1 610325:  Jan  5 09:01:00: SW2_SP:  Switch 1 Physical Slot 9 - Module Type LINE_CARD  inserted
Jan  5 09:01:01 vssrout1 610326:  Jan  5 09:01:00: SW2_SP:  Switch 1 Physical Slot 4 - Module Type LINE_CARD  inserted
Jan  5 09:01:02 vssrout1 610327: Jan  5 09:01:00: %SYS-SW1_SPSTBY-3-LOGGER_FLUSHED: System was paused for 00:00:04 to ensure console debugging output.
Jan  5 09:01:32 vssrout1 610358: Jan  5 09:01:31: %PARSER-6-EXPOSEDLOCKACQUIRED: Exclusive configuration lock acquired by user 'unknown' from terminal '1'  -Process= "SSH Process", ipl= 0, pid= 176
Jan  5 09:01:37 vssrout1 610364: Jan  5 09:01:37: %PARSER-5-CFGLOG_LOGGEDCMD: User:admin  logged command:ip access-list extended 100
Jan  5 09:01:47 vssrout1 610391: Jan  5 09:01:47: %PARSER-5-CFGLOG_LOGGEDCMD: User:admin  logged command:1020 permit ip 10.10.0.0 0.0.255.255 any
Jan  5 09:01:48 vssrout1 610392: Jan  5 09:01:47: Config Sync: Line-by-Line sync verifying failure on command:   1020 permit ip 10.10.0.0 0.0.255.255 any due to parser return error
Jan  5 09:01:49 vssrout1 610393: Jan  5 09:01:47: %RF-SW2_SP-5-RF_RELOAD: Peer reload. Reason: Proxy request to reload peer
Jan  5 09:01:49 vssrout1 610394: Jan  5 09:01:47: %SYS-SW1_SPSTBY-5-RELOAD: Reload requested - From Active Switch (Reload peer unit).
Jan  5 09:01:49 vssrout1 610395: Jan  5 09:01:49: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/5/4, changed state to down
Jan  5 09:01:49 vssrout1 610396: Jan  5 09:01:49: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel200, changed state to down
Jan  5 09:01:49 vssrout1 610397: Jan  5 09:01:49: %LINK-3-UPDOWN: Interface Port-channel200, changed state to down
Jan  5 09:01:49 vssrout1 610398: Jan  5 09:01:49: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/5/4, changed state to down
Jan  5 09:01:49 vssrout1 610399: Jan  5 09:01:49: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel100, changed state to down
Jan  5 09:01:49 vssrout1 610400: Jan  5 09:01:49: %LINK-3-UPDOWN: Interface Port-channel100, changed state to down
Jan  5 09:01:49 vssrout1 610401: Jan  5 09:01:49: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/5/4, changed state to down
Jan  5 09:01:49 vssrout1 610402: Jan  5 09:01:49: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/5/4, changed state to down
Jan  5 09:01:49 vssrout1 610403: Jan  5 09:01:49: %VSLP-SW2_SP-3-VSLP_LMP_FAIL_REASON: Te2/5/4: Disabled by Peer Reload Request
Jan  5 09:01:49 vssrout1 610404: Jan  5 09:01:49: %VSLP-SW2_SP-2-VSL_DOWN:   Last VSL interface Te2/5/4 went down
Jan  5 09:01:49 vssrout1 610405:  Jan  5 09:01:49: %VSLP-SW2_SP-2-VSL_DOWN:   All VSL links went down while switch is in ACTIVE role
Jan  5 09:01:49 vssrout1 610406: Jan  5 09:01:49: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/5/4, changed state to down
Jan  5 09:01:49 vssrout1 610407: Jan  5 09:01:49: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface Port-channel200, changed state to down
Jan  5 09:01:49 vssrout1 610408: Jan  5 09:01:49: %LINK-SW2_SP-3-UPDOWN: Interface Port-channel200, changed state to down
Jan  5 09:01:49 vssrout1 610409: Jan  5 09:01:49: %LINK-SW2_SP-3-UPDOWN: Interface TenGigabitEthernet2/5/4, changed state to down
Jan  5 09:01:49 vssrout1 610410: Jan  5 09:01:49: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface Port-channel100, changed state to down
Jan  5 09:01:49 vssrout1 610411: Jan  5 09:01:49: %LINK-SW2_SP-3-UPDOWN: Interface TenGigabitEthernet1/5/4, changed state to down
Jan  5 09:01:49 vssrout1 610412: Jan  5 09:01:49: %LINK-SW2_SP-3-UPDOWN: Interface Port-channel100, changed state to down
Jan  5 09:01:49 vssrout1 610413: Jan  5 09:01:49: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/5/4, changed state to down
Jan  5 09:01:50 vssrout1 610414: Jan  5 09:01:49: SW2_SP:  Switch 1 Physical Slot 5 - Module Type LINE_CARD  removed
Jan  5 09:01:50 vssrout1 610415:  Jan  5 09:01:49: SW2_SP:  Switch 1 Physical Slot 1 - Module Type LINE_CARD  removed
Jan  5 09:01:50 vssrout1 610416:  Jan  5 09:01:49: SW2_SP:  Switch 1 Physical Slot 2 - Module Type LINE_CARD  removed
Jan  5 09:01:50 vssrout1 610417:  Jan  5 09:01:49: SW2_SP:  Switch 1 Physical Slot 4 - Module Type LINE_CARD  removed
Jan  5 09:01:50 vssrout1 610418:  Jan  5 09:01:49: SW2_SP:  Switch 1 Physical Slot 9 - Module Type LINE_CARD  removed
Jan  5 09:01:50 vssrout1 610419:  Jan  5 09:01:49: SW2_SP: remote_bay_ps_remove: couldn't sync the event
Jan  5 09:01:51 vssrout1 610420: Jan  5 09:01:49: %PFREDUN-SW2_SP-6-ACTIVE: Standby processor removed or reloaded, changing to Simplex mode
Jan  5 09:01:54 vssrout1 610421: Jan  5 09:01:54: %SYS-5-CONFIG_I: Configured from console by admin on vty0 (x.x.x.x)
Jan  5 09:01:55 vssrout1 610422: Jan  5 09:01:54: %PARSER-6-EXPOSEDLOCKRELEASED: Exclusive configuration lock released from terminal '1' -Process= "SSH Process", ipl= 0, pid= 176
Jan  5 09:02:26 vssrout1 610424: Jan  5 09:02:26: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 09:02:26 vssrout1 610425: Jan  5 09:02:26: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B4AC 41F2B3E4 41FAE2A0 41AFA348 41B5C7A0 41FE453C 4059755C 406185A0 40618964 406186A0
Jan  5 09:02:26 vssrout1 610426: Jan  5 09:02:26: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 09:02:26 vssrout1 610427: Jan  5 09:02:26: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B514 41F2B3F4 41FAE2A0 41AFA348 41B5C7A0 41FE453C 4059755C 406185A0 40618964 406186A0
Jan  5 09:02:26 vssrout1 610428: Jan  5 09:02:26: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 09:02:26 vssrout1 610429: Jan  5 09:02:26: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B588 41F2B674 41F2B404 41FAE2A0 41AFA348 41B5C7A0 41FE453C 4059755C 406185A0 40618964
Jan  5 09:02:26 vssrout1 610430: Jan  5 09:02:26: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 09:02:26 vssrout1 610431: Jan  5 09:02:26: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B830 41F2B414 41FAE2A0 41AFA348 41B5C7A0 41FE453C 4059755C 406185A0 40618964 406186A0
Jan  5 09:02:26 vssrout1 610432: Jan  5 09:02:26: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 09:02:26 vssrout1 610433: Jan  5 09:02:26: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B780 41F2B424 41FAE2A0 41AFA348 41B5C7A0 41FE453C 4059755C 406185A0 40618964 406186A0
Jan  5 09:02:26 vssrout1 610434: Jan  5 09:02:26: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 09:02:26 vssrout1 610435: Jan  5 09:02:26: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B7D8 41F2B434 41FAE2A0 41AFA348 41B5C7A0 41FE453C 4059755C 406185A0 40618964 406186A0
Jan  5 09:02:26 vssrout1 610436: Jan  5 09:02:26: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 09:02:26 vssrout1 610437: Jan  5 09:02:26: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B4AC 41F2B3E4 41FAE2A0 41AFBD28 4059755C 406185A0 40618964 406186A0 405C3F48 4059B5B4
Jan  5 09:02:26 vssrout1 610438: Jan  5 09:02:26: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 09:02:26 vssrout1 610439: Jan  5 09:02:26: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B514 41F2B3F4 41FAE2A0 41AFBD28 4059755C 406185A0 40618964 406186A0 405C3F48 4059B5B4
Jan  5 09:02:26 vssrout1 610440: Jan  5 09:02:26: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 09:02:26 vssrout1 610441: Jan  5 09:02:26: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B588 41F2B674 41F2B404 41FAE2A0 41AFBD28 4059755C 406185A0 40618964 406186A0 405C3F48
Jan  5 09:02:26 vssrout1 610442: Jan  5 09:02:26: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 09:02:26 vssrout1 610443: Jan  5 09:02:26: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B830 41F2B414 41FAE2A0 41AFBD28 4059755C 406185A0 40618964 406186A0 405C3F48 4059B5B4
Jan  5 09:02:27 vssrout1 610444: Jan  5 09:02:26: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 09:02:27 vssrout1 610445: Jan  5 09:02:26: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B780 41F2B424 41FAE2A0 41AFBD28 4059755C 406185A0 40618964 406186A0 405C3F48 4059B5B4
Jan  5 09:02:27 vssrout1 610446: Jan  5 09:02:26: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 09:02:27 vssrout1 610447: Jan  5 09:02:26: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B7D8 41F2B434 41FAE2A0 41AFBD28 4059755C 406185A0 40618964 406186A0 405C3F48 4059B5B4
Jan  5 09:04:15 vssrout1 610448: Jan  5 09:04:14: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/5/4, changed state to up
Jan  5 09:04:16 vssrout1 610449: Jan  5 09:04:14: %LINK-SW2_SP-3-UPDOWN: Interface TenGigabitEthernet2/5/4, changed state to up
Jan  5 09:04:39 vssrout1 610450: Jan  5 09:04:37: %VSLP-SW2_SP-5-RRP_ROLE_RESOLVED: Role resolved as ACTIVE  by VSLP
Jan  5 09:04:39 vssrout1 610451: Jan  5 09:04:37: %VSL-SW2_SP-5-VSL_CNTRL_LINK:  New VSL Control Link Te2/5/4
Jan  5 09:04:39 vssrout1 610452:  Jan  5 09:04:37: %VSLP-SW2_SP-5-VSL_UP:  Ready for control traffic
Jan  5 09:06:30 vssrout1 610453: Jan  5 09:06:28: %PFREDUN-SW2_SP-6-ACTIVE: Standby initializing for SSO mode
Jan  5 09:06:42 vssrout1 610454: Jan  5 09:06:40: %PFINIT-SW2_SP-5-CONFIG_SYNC: Sync'ing the startup configuration to the standby Router.
Jan  5 09:07:20 vssrout1 610455: Jan  5 09:07:18: SW2_SP:  Switch 1 Physical Slot 5 - Module Type LINE_CARD  inserted
Jan  5 09:07:35 vssrout1 610456: Jan  5 09:07:35: %LINK-3-UPDOWN: Interface GigabitEthernet1/5/3, changed state to down
Jan  5 09:07:35 vssrout1 610457: Jan  5 09:07:35: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/5/4, changed state to down
Jan  5 09:07:35 vssrout1 610458: Jan  5 09:07:35: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/5/4, changed state to up
Jan  5 09:07:35 vssrout1 610459: Jan  5 09:07:35: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/5/4, changed state to up
Jan  5 09:07:35 vssrout1 610460: Jan  5 09:07:35: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/5/4, changed state to up
Jan  5 09:07:35 vssrout1 610461: Jan  5 09:07:35: %LINK-3-UPDOWN: Interface Port-channel200, changed state to up
Jan  5 09:07:35 vssrout1 610462: Jan  5 09:07:35: %LINK-3-UPDOWN: Interface Port-channel100, changed state to up
Jan  5 09:07:36 vssrout1 610463: Jan  5 09:07:35: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel200, changed state to up
Jan  5 09:07:36 vssrout1 610464: Jan  5 09:07:35: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel100, changed state to up
Jan  5 09:07:36 vssrout1 610465: Jan  5 09:07:35: %VSLP-SW2_SP-5-VSL_UP:  Ready for data traffic
Jan  5 09:07:36 vssrout1 610466:  Jan  5 09:07:35: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/5/4, changed state to up
Jan  5 09:07:36 vssrout1 610467: Jan  5 09:07:35: %LINK-SW2_SP-3-UPDOWN: Interface TenGigabitEthernet1/5/4, changed state to up
Jan  5 09:07:36 vssrout1 610468: Jan  5 09:07:35: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/5/4, changed state to up
Jan  5 09:07:36 vssrout1 610469: Jan  5 09:07:35: %LINK-SW2_SP-3-UPDOWN: Interface Port-channel200, changed state to up
Jan  5 09:07:36 vssrout1 610470: Jan  5 09:07:35: %LINK-SW2_SP-3-UPDOWN: Interface Port-channel100, changed state to up
Jan  5 09:07:37 vssrout1 610471: Jan  5 09:07:35: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface Port-channel200, changed state to up
Jan  5 09:07:37 vssrout1 610472: Jan  5 09:07:35: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface Port-channel100, changed state to up
Jan  5 09:07:38 vssrout1 610473: Jan  5 09:07:36: SW2_SP:  Card inserted in Switch_number = 1 ,
Jan  5 09:07:38 vssrout1 610474:                 physical slot 5, interfaces are now online
Jan  5 09:07:49 vssrout1 610475: Jan  5 09:07:48: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 09:07:49 vssrout1 610476: Jan  5 09:07:48: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B4AC 41F2B3E4 41FAE2A0 41AFA348 41B5C7A0 41FE453C 4059755C 4061D0E0 40618570 40618EFC
Jan  5 09:07:49 vssrout1 610477: Jan  5 09:07:48: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 09:07:49 vssrout1 610478: Jan  5 09:07:48: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B514 41F2B3F4 41FAE2A0 41AFA348 41B5C7A0 41FE453C 4059755C 4061D0E0 40618570 40618EFC
Jan  5 09:07:49 vssrout1 610479: Jan  5 09:07:48: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 09:07:49 vssrout1 610480: Jan  5 09:07:48: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B588 41F2B674 41F2B404 41FAE2A0 41AFA348 41B5C7A0 41FE453C 4059755C 4061D0E0 40618570
Jan  5 09:07:49 vssrout1 610481: Jan  5 09:07:48: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 09:07:49 vssrout1 610482: Jan  5 09:07:48: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B830 41F2B414 41FAE2A0 41AFA348 41B5C7A0 41FE453C 4059755C 4061D0E0 40618570 40618EFC
Jan  5 09:07:49 vssrout1 610483: Jan  5 09:07:48: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 09:07:49 vssrout1 610484: Jan  5 09:07:48: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B780 41F2B424 41FAE2A0 41AFA348 41B5C7A0 41FE453C 4059755C 4061D0E0 40618570 40618EFC
Jan  5 09:07:49 vssrout1 610485: Jan  5 09:07:48: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 09:07:49 vssrout1 610486: Jan  5 09:07:48: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B7D8 41F2B434 41FAE2A0 41AFA348 41B5C7A0 41FE453C 4059755C 4061D0E0 40618570 40618EFC
Jan  5 09:07:49 vssrout1 610487: Jan  5 09:07:48: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 09:07:49 vssrout1 610488: Jan  5 09:07:48: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B4AC 41F2B3E4 41FAE2A0 41AFBD28 4059755C 4061D0E0 40618570 40618EFC 42473E68 41FBD7F4
Jan  5 09:07:49 vssrout1 610489: Jan  5 09:07:48: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 09:07:49 vssrout1 610490: Jan  5 09:07:48: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B514 41F2B3F4 41FAE2A0 41AFBD28 4059755C 4061D0E0 40618570 40618EFC 42473E68 41FBD7F4
Jan  5 09:07:49 vssrout1 610491: Jan  5 09:07:48: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 09:07:49 vssrout1 610492: Jan  5 09:07:48: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B588 41F2B674 41F2B404 41FAE2A0 41AFBD28 4059755C 4061D0E0 40618570 40618EFC 42473E68
Jan  5 09:07:49 vssrout1 610493: Jan  5 09:07:48: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 09:07:49 vssrout1 610494: Jan  5 09:07:48: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B830 41F2B414 41FAE2A0 41AFBD28 4059755C 4061D0E0 40618570 40618EFC 42473E68 41FBD7F4
Jan  5 09:07:49 vssrout1 610495: Jan  5 09:07:48: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 09:07:49 vssrout1 610496: Jan  5 09:07:48: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B780 41F2B424 41FAE2A0 41AFBD28 4059755C 4061D0E0 40618570 40618EFC 42473E68 41FBD7F4
Jan  5 09:07:49 vssrout1 610497: Jan  5 09:07:48: vs_get_pslot_switch_id():vslot error..! vslot=0xFFFF
Jan  5 09:07:49 vssrout1 610498: Jan  5 09:07:48: -Traceback= 424E833C 42A20C50 42A21064 422050D8 422054C0 422057AC 41F2B7D8 41F2B434 41FAE2A0 41AFBD28 4059755C 4061D0E0 40618570 40618EFC 42473E68 41FBD7F4
Jan  5 09:08:40 vssrout1 610499: *Jan  5 08:07:07.263: SW1_SPSTBY: SP: Currently running ROMMON from S (Gold) region
Jan  5 09:08:40 vssrout1 610500: Jan  5 08:07:16.231: %C6KPWR-SW1_SPSTBY-4-PSOK: power supply 1 turned on.
Jan  5 09:08:40 vssrout1 610501: Jan  5 08:07:18.247: %FABRIC-SW1_SPSTBY-5-CLEAR_BLOCK: Clear block option is off for the fabric in slot 5.
Jan  5 09:08:40 vssrout1 610502: Jan  5 08:07:18.247: %FABRIC-SW1_SPSTBY-5-FABRIC_MODULE_ACTIVE: The Switch Fabric Module in slot 5 became active.
Jan  5 09:08:40 vssrout1 610503: Jan  5 08:07:18.875: %DIAG-SW1_SPSTBY-6-RUN_MINIMUM: Switch 1 Module 5: Running Minimal Diagnostics...
Jan  5 09:08:40 vssrout1 610504: Jan  5 08:07:18.923: %CONST_DIAG-SW1_SPSTBY-6-DIAG_PORT_SKIPPED: Module 5 port 4 is skipped in TestLoopback due to: the port is used as a VSL link.
Jan  5 09:08:40 vssrout1 610505: Jan  5 08:07:22.575: %CONST_DIAG-SW1_SPSTBY-6-DIAG_PORT_SKIPPED: Module 5 port 4 is skipped in TestChannel due to: the port is used as a VSL link.
Jan  5 09:08:40 vssrout1 610506: Jan  5 08:07:30.168: %DIAG-SW1_SPSTBY-6-DIAG_OK: Switch 1 Module 5: Passed Online Diagnostics
Jan  5 09:08:40 vssrout1 610507: Jan  5 08:07:31.375: %C6KENV-SW1_SPSTBY-4-USE_RED_CLOCK: system is using the redundant clock (clock B).
Jan  5 09:08:40 vssrout1 610508: Jan  5 08:08:34.729: %SYS-SW1_SPSTBY-5-RESTART: System restarted --
Jan  5 09:08:40 vssrout1 610509: Cisco IOS Software, s72033_sp Software (s72033_sp-ADVENTERPRISEK9-M), Version 12.2(33)SXI1, RELEASE SOFTWARE (fc3)
Jan  5 09:08:40 vssrout1 610510: Technical Support: http://www.cisco.com/techsupport
Jan  5 09:08:40 vssrout1 610511: Copyright (c) 1986-2009 by Cisco Systems, Inc.
Jan  5 09:08:40 vssrout1 610512: Compiled Sat 28-Mar-09 10:48 by prod_rel_team
Jan  5 09:08:41 vssrout1 610513: Jan  5 09:08:36: %SYS-SW1_SPSTBY-6-BOOTTIME: Time taken to reboot after reload =  407 seconds
Jan  5 09:08:44 vssrout1 610514: Jan  5 09:08:39: %SYS-SW1_SPSTBY-3-LOGGER_FLUSHED: System was paused for 00:02:09 to ensure console debugging output.
Jan  5 09:08:47 vssrout1 610515: IPC SSO ERROR: Session count execeeded
Jan  5 09:08:56 vssrout1 610516: Jan  5 09:08:55: %HA_CONFIG_SYNC-6-BULK_CFGSYNC_SUCCEED: Bulk Sync succeeded
Jan  5 09:08:56 vssrout1 610517: Jan  5 09:08:55: %PFREDUN-SW1_SPSTBY-6-STANDBY: Ready for SSO mode
Jan  5 09:08:57 vssrout1 610518: Jan  5 09:08:55: %RF-SW2_SP-5-RF_TERMINAL_STATE: Terminal state reached for (SSO)
Jan  5 09:09:00 vssrout1 610519: Jan  5 09:08:57: %C6KENV-SW1_SPSTBY-4-FANHPMODE: Switch 1 Fan-tray 1 is operating in high power mode
Jan  5 09:09:00 vssrout1 610520: Jan  5 09:08:59: SW2_SP:  Switch 1 Physical Slot 1 - Module Type LINE_CARD  inserted
Jan  5 09:09:00 vssrout1 610521:  Jan  5 09:08:59: SW2_SP:  Switch 1 Physical Slot 2 - Module Type LINE_CARD  inserted
Jan  5 09:09:00 vssrout1 610522:  Jan  5 09:08:59: SW2_SP:  Switch 1 Physical Slot 9 - Module Type LINE_CARD  inserted
Jan  5 09:09:00 vssrout1 610523:  Jan  5 09:08:59: SW2_SP:  Switch 1 Physical Slot 4 - Module Type LINE_CARD  inserted
Jan  5 09:09:01 vssrout1 610524: Jan  5 09:08:58: %SYS-SW1_SPSTBY-3-LOGGER_FLUSHED: System was paused for 00:00:04 to ensure console debugging output.
Jan  5 09:10:04 vssrout1 610525: Jan  5 09:10:02: %C6KENV-SW1_SPSTBY-4-FANHPMODE: Switch 1 Fan-tray 1 is operating in high power mode
Jan  5 09:10:14 vssrout1 610526: Jan  5 09:10:12: %C6KENV-SW1_SPSTBY-4-FANHPMODE: Switch 2 Fan-tray 1 is operating in high power mode
Jan  5 09:10:25 vssrout1 610527: Jan  5 09:10:23: %DIAG-SW1_SPSTBY-6-RUN_MINIMUM: Switch 1 Module 4: Running Minimal Diagnostics...
Jan  5 09:10:26 vssrout1 610528: *Mar  1 00:00:02.763: DaughterBoard (Distributed Forwarding Card 3)
Jan  5 09:10:26 vssrout1 610529:  Firmware compiled 19-Feb-09 20:18 by weizhan Build [100]
Jan  5 09:10:26 vssrout1 610530:   Jan  5 08:10:21.623: DFC4: Switch mode info received by DFC..!
Jan  5 09:10:26 vssrout1 610531: Jan  5 08:10:21.647: %SYS-DFC4-5-RESTART: System restarted --
Jan  5 09:10:27 vssrout1 610532: Cisco IOS Software, c6lc2 Software (c6lc2-SP-M), Version 12.2(33)SXI1, RELEASE SOFTWARE (fc3)
Jan  5 09:10:27 vssrout1 610533: Technical Support: http://www.cisco.com/techsupport
Jan  5 09:10:27 vssrout1 610534: Copyright (c) 1986-2009 by Cisco Systems, Inc.
Jan  5 09:10:27 vssrout1 610535: Compiled Sat 28-Mar-09 10:29 by prod_rel_team
Jan  5 09:10:27 vssrout1 610536: Jan  5 08:10:21.655: DFC4: Currently running ROMMON from S (Gold) region
Jan  5 09:10:33 vssrout1 610537: Jan  5 09:10:31: %DIAG-SW1_SPSTBY-6-RUN_MINIMUM: Switch 1 Module 2: Running Minimal Diagnostics...
Jan  5 09:10:33 vssrout1 610538: *Mar  1 00:00:04.139: DaughterBoard (Distributed Forwarding Card 3)
Jan  5 09:10:33 vssrout1 610539:  Firmware compiled 19-Feb-09 20:18 by weizhan Build [100]
Jan  5 09:10:33 vssrout1 610540:       Jan  5 08:10:29.436: DFC2: Switch mode info received by DFC..!
Jan  5 09:10:33 vssrout1 610541: Jan  5 08:10:29.911: %SYS-DFC2-5-RESTART: System restarted --
Jan  5 09:10:34 vssrout1 610542: Cisco IOS Software, c6lc2 Software (c6lc2-SP-M), Version 12.2(33)SXI1, RELEASE SOFTWARE (fc3)
Jan  5 09:10:34 vssrout1 610543: Technical Support: http://www.cisco.com/techsupport
Jan  5 09:10:34 vssrout1 610544: Copyright (c) 1986-2009 by Cisco Systems, Inc.
Jan  5 09:10:34 vssrout1 610545: Compiled Sat 28-Mar-09 10:29 by prod_rel_team
Jan  5 09:10:34 vssrout1 610546: Jan  5 08:10:29.919: DFC2: Currently running ROMMON from S (Gold) region
Jan  5 09:10:40 vssrout1 610547: Jan  5 09:10:38: %DIAG-SW1_SPSTBY-6-RUN_MINIMUM: Switch 1 Module 1: Running Minimal Diagnostics...
Jan  5 09:10:41 vssrout1 610548: *Mar  1 00:00:04.135: DaughterBoard (Distributed Forwarding Card 3)
Jan  5 09:10:41 vssrout1 610549:  Firmware compiled 19-Feb-09 20:18 by weizhan Build [100]
Jan  5 09:10:41 vssrout1 610550:       Jan  5 08:10:30.000: DFC1: Switch mode info received by DFC..!
Jan  5 09:10:41 vssrout1 610551: Jan  5 08:10:36.135: %SYS-DFC1-5-RESTART: System restarted --
Jan  5 09:10:42 vssrout1 610552: Cisco IOS Software, c6lc2 Software (c6lc2-SP-M), Version 12.2(33)SXI1, RELEASE SOFTWARE (fc3)
Jan  5 09:10:42 vssrout1 610553: Technical Support: http://www.cisco.com/techsupport
Jan  5 09:10:42 vssrout1 610554: Copyright (c) 1986-2009 by Cisco Systems, Inc.
Jan  5 09:10:42 vssrout1 610555: Compiled Sat 28-Mar-09 10:29 by prod_rel_team
Jan  5 09:10:42 vssrout1 610556: Jan  5 08:10:36.139: DFC1: Currently running ROMMON from S (Gold) region
Jan  5 09:10:53 vssrout1 610557: Jan  5 09:10:50: %DIAG-SW1_SPSTBY-6-DIAG_OK: Switch 1 Module 4: Passed Online Diagnostics
Jan  5 09:10:55 vssrout1 610558: Jan  5 09:10:54: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/1, changed state to down
Jan  5 09:10:55 vssrout1 610559: Jan  5 09:10:55: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/2, changed state to down
Jan  5 09:10:55 vssrout1 610560: Jan  5 09:10:55: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/3, changed state to down
Jan  5 09:10:57 vssrout1 610561: Jan  5 09:10:56: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/4, changed state to down
Jan  5 09:10:57 vssrout1 610562: Jan  5 09:10:56: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/2, changed state to up
Jan  5 09:10:57 vssrout1 610563: Jan  5 09:10:56: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/5, changed state to down
Jan  5 09:10:57 vssrout1 610564: Jan  5 09:10:57: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/1, changed state to up
Jan  5 09:10:57 vssrout1 610565: Jan  5 09:10:57: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/3, changed state to up
Jan  5 09:10:57 vssrout1 610566: Jan  5 09:10:57: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/6, changed state to down
Jan  5 09:10:58 vssrout1 610567: Jan  5 09:10:56: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/2, changed state to up
Jan  5 09:10:58 vssrout1 610568: Jan  5 09:10:57: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/1, changed state to up
Jan  5 09:10:58 vssrout1 610569: Jan  5 09:10:57: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/3, changed state to up
Jan  5 09:10:58 vssrout1 610570: Jan  5 09:10:57: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/4, changed state to up
Jan  5 09:10:58 vssrout1 610571: Jan  5 09:10:57: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/7, changed state to down
Jan  5 09:10:58 vssrout1 610572: Jan  5 09:10:57: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/8, changed state to down
Jan  5 09:10:58 vssrout1 610573: Jan  5 09:10:58: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/5, changed state to up
Jan  5 09:10:58 vssrout1 610574: Jan  5 09:10:58: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/11, changed state to down
Jan  5 09:10:59 vssrout1 610575: Jan  5 09:10:57: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/4, changed state to up
Jan  5 09:10:59 vssrout1 610576: Jan  5 09:10:58: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/5, changed state to up
Jan  5 09:10:59 vssrout1 610577: Jan  5 09:10:58: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/6, changed state to up
Jan  5 09:10:59 vssrout1 610578: Jan  5 09:10:58: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/12, changed state to down
Jan  5 09:10:59 vssrout1 610579: Jan  5 09:10:59: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/7, changed state to up
Jan  5 09:10:59 vssrout1 610580: Jan  5 09:10:59: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/8, changed state to up
Jan  5 09:10:59 vssrout1 610581: Jan  5 09:10:59: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/13, changed state to down
Jan  5 09:11:00 vssrout1 610582: Jan  5 09:10:58: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/6, changed state to up
Jan  5 09:11:00 vssrout1 610583: Jan  5 09:10:59: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/7, changed state to up
Jan  5 09:11:00 vssrout1 610584: Jan  5 09:10:59: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/8, changed state to up
Jan  5 09:11:00 vssrout1 610585: Jan  5 09:10:59: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/11, changed state to up
Jan  5 09:11:00 vssrout1 610586: Jan  5 09:10:59: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/14, changed state to down
Jan  5 09:11:00 vssrout1 610587: Jan  5 09:11:00: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/12, changed state to up
Jan  5 09:11:00 vssrout1 610588: Jan  5 09:11:00: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/15, changed state to down
Jan  5 09:11:01 vssrout1 610589: Jan  5 09:10:59: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/11, changed state to up
Jan  5 09:11:01 vssrout1 610590: Jan  5 09:11:00: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/12, changed state to up
Jan  5 09:11:01 vssrout1 610591: Jan  5 09:11:00: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/16, changed state to down
Jan  5 09:11:01 vssrout1 610592: Jan  5 09:11:01: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/13, changed state to up
Jan  5 09:11:01 vssrout1 610593: Jan  5 09:11:01: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/14, changed state to up
Jan  5 09:11:01 vssrout1 610594: Jan  5 09:11:01: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/17, changed state to down
Jan  5 09:11:01 vssrout1 610595: Jan  5 09:11:01: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/2, changed state to up
Jan  5 09:11:01 vssrout1 610596: Jan  5 09:11:01: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/13, changed state to up
Jan  5 09:11:01 vssrout1 610597: Jan  5 09:11:01: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/14, changed state to up
Jan  5 09:11:01 vssrout1 610598: Jan  5 09:11:01: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/18, changed state to down
Jan  5 09:11:01 vssrout1 610599: Jan  5 09:11:01: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/15, changed state to up
Jan  5 09:11:01 vssrout1 610600: Jan  5 09:11:01: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/16, changed state to up
Jan  5 09:11:02 vssrout1 610601: Jan  5 09:11:01: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/2, changed state to up
Jan  5 09:11:02 vssrout1 610602: Jan  5 09:11:02: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/1, changed state to up
Jan  5 09:11:02 vssrout1 610603: Jan  5 09:11:02: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/3, changed state to up
Jan  5 09:11:03 vssrout1 610604: Jan  5 09:11:02: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/17, changed state to up
Jan  5 09:11:03 vssrout1 610605: Jan  5 09:11:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/18, changed state to up
Jan  5 09:11:03 vssrout1 610606: Jan  5 09:11:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/4, changed state to up
Jan  5 09:11:03 vssrout1 610607: Jan  5 09:11:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/6, changed state to up
Jan  5 09:11:03 vssrout1 610608: Jan  5 09:11:01: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/15, changed state to up
Jan  5 09:11:03 vssrout1 610609: Jan  5 09:11:01: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/16, changed state to up
Jan  5 09:11:03 vssrout1 610610: Jan  5 09:11:02: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/1, changed state to up
Jan  5 09:11:03 vssrout1 610611: Jan  5 09:11:02: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/3, changed state to up
Jan  5 09:11:04 vssrout1 610612: Jan  5 09:11:02: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/17, changed state to up
Jan  5 09:11:04 vssrout1 610613: Jan  5 09:11:03: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/18, changed state to up
Jan  5 09:11:04 vssrout1 610614: Jan  5 09:11:04: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/5, changed state to up
Jan  5 09:11:04 vssrout1 610615: Jan  5 09:11:04: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/8, changed state to up
Jan  5 09:11:04 vssrout1 610616: Jan  5 09:11:04: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/7, changed state to up
Jan  5 09:11:04 vssrout1 610617: Jan  5 09:11:03: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/4, changed state to up
Jan  5 09:11:04 vssrout1 610618: Jan  5 09:11:03: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/6, changed state to up
Jan  5 09:11:04 vssrout1 610619: Jan  5 09:11:04: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/5, changed state to up
Jan  5 09:11:05 vssrout1 610620: Jan  5 09:11:04: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/8, changed state to up
Jan  5 09:11:05 vssrout1 610621: Jan  5 09:11:04: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/7, changed state to up
Jan  5 09:11:05 vssrout1 610622: Jan  5 09:11:05: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/11, changed state to up
Jan  5 09:11:06 vssrout1 610623: Jan  5 09:11:05: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/19, changed state to down
Jan  5 09:11:06 vssrout1 610624: Jan  5 09:11:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/12, changed state to up
Jan  5 09:11:06 vssrout1 610625: Jan  5 09:11:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/13, changed state to up
Jan  5 09:11:06 vssrout1 610626: Jan  5 09:11:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/14, changed state to up
Jan  5 09:11:06 vssrout1 610627: Jan  5 09:11:06: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/19, changed state to up
Jan  5 09:11:07 vssrout1 610628: Jan  5 09:11:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/19, changed state to up
Jan  5 09:11:07 vssrout1 610629: Jan  5 09:11:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/16, changed state to up
Jan  5 09:11:07 vssrout1 610630: Jan  5 09:11:07: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/15, changed state to up
Jan  5 09:11:07 vssrout1 610631: Jan  5 09:11:06: %DIAG-SW1_SPSTBY-6-DIAG_OK: Switch 1 Module 1: Passed Online Diagnostics
Jan  5 09:11:07 vssrout1 610632: Jan  5 09:11:06: %DIAG-SW1_SPSTBY-6-RUN_MINIMUM: Switch 1 Module 9: Running Minimal Diagnostics...
Jan  5 09:11:08 vssrout1 610633: Jan  5 09:11:07: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/17, changed state to up
Jan  5 09:11:08 vssrout1 610634: Jan  5 09:11:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/18, changed state to up
Jan  5 09:11:08 vssrout1 610635: Jan  5 09:11:05: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/11, changed state to up
Jan  5 09:11:08 vssrout1 610636: Jan  5 09:11:06: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/12, changed state to up
Jan  5 09:11:08 vssrout1 610637: Jan  5 09:11:06: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/13, changed state to up
Jan  5 09:11:08 vssrout1 610638: Jan  5 09:11:06: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/14, changed state to up
Jan  5 09:11:08 vssrout1 610639: Jan  5 09:11:06: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/19, changed state to up
Jan  5 09:11:09 vssrout1 610640: Jan  5 09:11:06: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/19, changed state to up
Jan  5 09:11:09 vssrout1 610641: Jan  5 09:11:06: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/16, changed state to up
Jan  5 09:11:09 vssrout1 610642: Jan  5 09:11:07: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/15, changed state to up
Jan  5 09:11:09 vssrout1 610643: Jan  5 09:11:07: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/17, changed state to up
Jan  5 09:11:09 vssrout1 610644: Jan  5 09:11:08: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/18, changed state to up
Jan  5 09:11:10 vssrout1 610645: Jan  5 09:11:09: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/20, changed state to down
Jan  5 09:11:10 vssrout1 610646: Jan  5 09:11:09: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/21, changed state to down
Jan  5 09:11:11 vssrout1 610647: Jan  5 09:11:10: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/22, changed state to down
Jan  5 09:11:11 vssrout1 610648: Jan  5 09:11:10: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/20, changed state to up
Jan  5 09:11:11 vssrout1 610649: Jan  5 09:11:10: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/21, changed state to up
Jan  5 09:11:11 vssrout1 610650: Jan  5 09:11:10: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/23, changed state to down
Jan  5 09:11:11 vssrout1 610651: Jan  5 09:11:11: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/22, changed state to up
Jan  5 09:11:11 vssrout1 610652: Jan  5 09:11:10: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/20, changed state to up
Jan  5 09:11:11 vssrout1 610653: Jan  5 09:11:10: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/21, changed state to up
Jan  5 09:11:11 vssrout1 610654: Jan  5 09:11:11: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/22, changed state to up
Jan  5 09:11:11 vssrout1 610655: Jan  5 09:11:11: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/23, changed state to up
Jan  5 09:11:12 vssrout1 610656: Jan  5 09:11:11: SW2_SP:  Card inserted in Switch_number = 1 ,
Jan  5 09:11:12 vssrout1 610657:                 physical slot 4, interfaces are now online
Jan  5 09:11:13 vssrout1 610658: Jan  5 09:11:11: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/4/23, changed state to up
Jan  5 09:11:13 vssrout1 610659: Jan  5 09:11:13: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/1, changed state to down
Jan  5 09:11:14 vssrout1 610660: Jan  5 09:11:13: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/20, changed state to up
Jan  5 09:11:14 vssrout1 610661: Jan  5 09:11:14: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/4, changed state to down
Jan  5 09:11:14 vssrout1 610662: Jan  5 09:11:14: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/8, changed state to down
Jan  5 09:11:15 vssrout1 610663: Jan  5 09:11:13: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/20, changed state to up
Jan  5 09:11:15 vssrout1 610664: Jan  5 09:11:15: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/21, changed state to up
Jan  5 09:11:16 vssrout1 610665: Jan  5 09:11:15: SW2_SP:  Card inserted in Switch_number = 1 ,
Jan  5 09:11:16 vssrout1 610666:                 physical slot 1, interfaces are now online
Jan  5 09:11:17 vssrout1 610667: Jan  5 09:11:16: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/22, changed state to up
Jan  5 09:11:17 vssrout1 610668: Jan  5 09:11:15: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/21, changed state to up
Jan  5 09:11:17 vssrout1 610669: Jan  5 09:11:16: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/22, changed state to up
Jan  5 09:11:17 vssrout1 610670: Jan  5 09:11:16: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/23, changed state to up
Jan  5 09:11:18 vssrout1 610671: Jan  5 09:11:17: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/23, changed state to up
Jan  5 09:11:19 vssrout1 610672: Jan  5 09:11:18: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/1/1, changed state to up
Jan  5 09:11:19 vssrout1 610673: Jan  5 09:11:19: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/1, changed state to up
Jan  5 09:11:19 vssrout1 610674: Jan  5 09:11:19: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/4, changed state to up
Jan  5 09:11:20 vssrout1 610675: Jan  5 09:11:18: %LINK-SW2_SP-3-UPDOWN: Interface TenGigabitEthernet2/1/1, changed state to up
Jan  5 09:11:20 vssrout1 610676: Jan  5 09:11:19: %LINK-SW2_SP-3-UPDOWN: Interface TenGigabitEthernet1/1/1, changed state to up
Jan  5 09:11:20 vssrout1 610677: Jan  5 09:11:19: %LINK-SW2_SP-3-UPDOWN: Interface TenGigabitEthernet1/1/4, changed state to up
Jan  5 09:11:20 vssrout1 610678: Jan  5 09:11:19: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/8, changed state to up
Jan  5 09:11:22 vssrout1 610679: Jan  5 09:11:20: %LINK-SW2_SP-3-UPDOWN: Interface TenGigabitEthernet1/1/8, changed state to up
Jan  5 09:11:23 vssrout1 610680: Jan  5 09:11:22: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/8, changed state to up
Jan  5 09:11:24 vssrout1 610681: Jan  5 09:11:22: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/8, changed state to up
Jan  5 09:11:25 vssrout1 610682: Jan  5 09:11:25: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/4, changed state to up
Jan  5 09:11:25 vssrout1 610683: Jan  5 09:11:25: %LINK-3-UPDOWN: Interface Port-channel90, changed state to up
Jan  5 09:11:25 vssrout1 610684: Jan  5 09:11:25: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel90, changed state to up
Jan  5 09:11:25 vssrout1 610685: Jan  5 09:11:25: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/4, changed state to up
Jan  5 09:11:25 vssrout1 610686: Jan  5 09:11:25: %LINK-SW2_SP-3-UPDOWN: Interface Port-channel90, changed state to up
Jan  5 09:11:26 vssrout1 610687: Jan  5 09:11:24: %DIAG-SW1_SPSTBY-6-DIAG_OK: Switch 1 Module 2: Passed Online Diagnostics
Jan  5 09:11:26 vssrout1 610688: Jan  5 09:11:25: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface Port-channel90, changed state to up
Jan  5 09:11:31 vssrout1 610690: Jan  5 09:11:29: %DIAG-SW1_SPSTBY-6-DIAG_OK: Switch 1 Module 9: Passed Online Diagnostics
Jan  5 09:11:33 vssrout1 610691: Jan  5 09:11:32: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/2/1, changed state to down
Jan  5 09:11:33 vssrout1 610692: Jan  5 09:11:32: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/2/8, changed state to down
Jan  5 09:11:35 vssrout1 610693: Jan  5 09:11:33: SW2_SP:  Card inserted in Switch_number = 1 ,
Jan  5 09:11:35 vssrout1 610694:                 physical slot 2, interfaces are now online
Jan  5 09:11:37 vssrout1 610695: Jan  5 09:11:36: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/1/1, changed state to up
Jan  5 09:11:37 vssrout1 610696: Jan  5 09:11:36: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/1, changed state to up
Jan  5 09:11:38 vssrout1 610697: Jan  5 09:11:36: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/1/1, changed state to up
Jan  5 09:11:38 vssrout1 610698: Jan  5 09:11:36: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/1, changed state to up
Jan  5 09:11:39 vssrout1 610699: Jan  5 09:11:37: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/2/8, changed state to up
Jan  5 09:11:39 vssrout1 610700: Jan  5 09:11:37: %LINK-SW2_SP-3-UPDOWN: Interface TenGigabitEthernet1/2/8, changed state to up
Jan  5 09:11:41 vssrout1 610701: Jan  5 09:11:40: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/2/8, changed state to up
Jan  5 09:11:41 vssrout1 610702: Jan  5 09:11:41: %LINK-5-CHANGED: Interface Port-channel585, changed state to administratively down
Jan  5 09:11:43 vssrout1 610703: Jan  5 09:11:40: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/2/8, changed state to up
Jan  5 09:11:43 vssrout1 610704: Jan  5 09:11:41: %LINK-SW2_SP-5-CHANGED: Interface Port-channel585, changed state to administratively down
Jan  5 09:11:45 vssrout1 610705: Jan  5 09:11:45: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9/1, changed state to up
Jan  5 09:11:45 vssrout1 610706: Jan  5 09:11:45: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel585, changed state to up
Jan  5 09:11:45 vssrout1 610707: Jan  5 09:11:44: %LINK-SW2_SP-3-UPDOWN: Interface Port-channel585, changed state to down
Jan  5 09:11:45 vssrout1 610708: Jan  5 09:11:45: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/9/1, changed state to down
Jan  5 09:11:45 vssrout1 610709: Jan  5 09:11:45: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/9/1, changed state to up
Jan  5 09:11:45 vssrout1 610710: Jan  5 09:11:45: %LINK-SW2_SP-3-UPDOWN: Interface Port-channel585, changed state to up
Jan  5 09:11:45 vssrout1 610711: Jan  5 09:11:45: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9/1, changed state to up
Jan  5 09:11:45 vssrout1 610712: Jan  5 09:11:45: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface Port-channel585, changed state to up
Jan  5 09:11:45 vssrout1 610713: Jan  5 09:11:45: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9/2, changed state to up
Jan  5 09:11:45 vssrout1 610714: Jan  5 09:11:45: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/9/2, changed state to down
Jan  5 09:11:45 vssrout1 610715: Jan  5 09:11:45: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/9/2, changed state to up
Jan  5 09:11:46 vssrout1 610716: Jan  5 09:11:45: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9/2, changed state to up
Jan  5 09:11:46 vssrout1 610717: Jan  5 09:11:45: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9/3, changed state to up
Jan  5 09:11:46 vssrout1 610718: Jan  5 09:11:45: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/9/3, changed state to down
Jan  5 09:11:46 vssrout1 610719: Jan  5 09:11:45: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/9/3, changed state to up
Jan  5 09:11:46 vssrout1 610720: Jan  5 09:11:45: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9/3, changed state to up
Jan  5 09:11:46 vssrout1 610721: Jan  5 09:11:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9/4, changed state to up
Jan  5 09:11:46 vssrout1 610722: Jan  5 09:11:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/9/4, changed state to down
Jan  5 09:11:46 vssrout1 610723: Jan  5 09:11:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/9/4, changed state to up
Jan  5 09:11:46 vssrout1 610724: Jan  5 09:11:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9/4, changed state to up
Jan  5 09:11:46 vssrout1 610725: Jan  5 09:11:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9/5, changed state to up
Jan  5 09:11:47 vssrout1 610726: Jan  5 09:11:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/9/5, changed state to down
Jan  5 09:11:47 vssrout1 610727: Jan  5 09:11:46: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/9/5, changed state to up
Jan  5 09:11:47 vssrout1 610728: Jan  5 09:11:46: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9/5, changed state to up
Jan  5 09:11:47 vssrout1 610729: Jan  5 09:11:47: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9/6, changed state to up
Jan  5 09:11:48 vssrout1 610730: Jan  5 09:11:47: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/9/6, changed state to down
Jan  5 09:11:48 vssrout1 610731: Jan  5 09:11:47: %LINK-SW2_SP-3-UPDOWN: Interface GigabitEthernet1/9/6, changed state to up
Jan  5 09:11:49 vssrout1 610732: Jan  5 09:11:47: %LINEPROTO-SW2_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9/6, changed state to up
Jan  5 09:11:50 vssrout1 610733: Jan  5 09:11:48: SW2_SP:  Card inserted in Switch_number = 1 ,
Jan  5 09:11:50 vssrout1 610734:                 physical slot 9, interfaces are now online
Everyone's tags (1)
1 REPLY
VIP Super Bronze
Re: Catalyst 6509 - VSS - standby reloads unexpected
Hi Mike,
We had the same issues with SXI1 and SX2.  There are few nasty bug in theses codes. Our VSS boxes (some time primary and some times the secondary) would reload unexpectedly.  Since you are running SXI1 which is almost a year old, I would upgrade to SXI2a or SXI3.  I have SXI2a running for the last 5 months with no problems. (knock on wood) We also testing SXI3 in the lab.
Reza
3615
