Catalyst 6513 - Extended system ID issue
Hi Sir,
I have a Catalyst 6513 with SUP720. IOS version is 12.2(18)SXF12. I enabled extended system ID as follows:
spanning-tree mode pvst
spanning-tree vlan 1 priority 12288
Switch#sh spann vla 1
VLAN0001
Spanning tree enabled protocol ieee
Root ID Priority 12289
Address 0011.5d64.6480
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 12289 (priority 12288 sys-id-ext 1)
Aging Time 300
Switch#sh span sum
Switch is in pvst mode
Root bridge for: VLAN0001
EtherChannel misconfig guard is enabled
Extended system ID is disabled
Portfast Default is disabled
PortFast BPDU Guard Default is disabled
Portfast BPDU Filter Default is disabled
Loopguard Default is disabled
UplinkFast is disabled
BackboneFast is disabled
Pathcost method used is short
From the output of "sh spanning-tree vlan 1", it seems to show the switch is using extended system ID. However the output of "sh spanning-tree summary" shows extended system ID is disabled. Why? Is it just cosmetic issue?
I have another exactly identical Catalyst 6513 that shows extended sys ID is enabled in the output of "sh spann summ".
Please advise.
Thank you.
B.Rgds,
Lim TS
Silver
Re: Catalyst 6513 - Extended system ID issue
Better you migrate to higher version.
Hall of Fame Super Bronze
Please post the output from typing
sh catalyst6000
__
Edison.
BTW, looking at the output a bit closer, you are looking at a cosmetic bug.
If you see these 2 entries.
Extended system ID is enabled.
The purpose of the command is to add the Vlan number + the configured priority for such Vlan.
HTH,
__
Edison.
177
