Catalyst and IPSec
Dear all,
hope you can help me with my issue.
I need to know which catalyst i need for encryption. Is there a possibility with catalyst 2960, 3560 or 3750? thanks&brgds Rainer
1 REPLY
Re: Catalyst and IPSec
You couldn't mount A VPN IPsec tunnel with the catalyst 2960, 3560 or 3750 switches. You should have a router or an appliance like AS or PIX for the encryption.
Plz rate if helped.
Br
160
