10-06-2010 12:48 PM - edited 03-06-2019 01:21 PM
Will the 512MB Compact Flash Card part number 16-3397-01 work in the Cisco 6509 ?
Solved! Go to Solution.
10-06-2010 12:59 PM
Chad,
That should work fine. You may have to format the card if it came from another platform like a router.
Hope it helps.
10-06-2010 12:59 PM
Chad,
Hope it helps.
10-06-2010 01:08 PM
Thanks Collin!
10-06-2010 02:23 PM
Maximum size of the CF (third party) is 2Gb.
