Community Member
Catalyst Express 500 and 802.1X failed authentication vlan
One of my customers wants to configure his access ports like this:
1. Enable 802.1X and use radius to assign vlan to known computers.
2. Computers failing authentication should get access to the guest vlan (default vlan).
Can I do one or both using the Catalyst Express 500 series?
Vigleik
Community Member
Re: Catalyst Express 500 and 802.1X failed authentication vlan
Yes, you can do with Catalyst Expresss 500 series.
Community Member
Please provide documentation or otherwise explain how to give computers failing authentication access to the guest vlan.
Have you tried that yourself, or have you found a document stating that this is possible ?
Vigleik.
Hi VIGLEIK ,
You can do the both using 802.1x on CE500.
The configuration for 802.1X and Radius authentication server can be done with the help of Cisco Network Assistant (CNA). In the menu Network Security Settings you have to put the
security level on high. There is the ossibility to configure the IP address of the RADIUS
server and the RADIUS key.
In case you don?t have the CNA, you can download it for free from:
http://www.cisco.com/cgi-bin/tablebuild.pl/NetworkAssistant
HTH, Please rate if it does.
-amit singh
356
