Catalyst Express 500
Hi all,
I have a simple question for you, I need the path to modify advanced settings through the browser e.g. http://switchname/en/privilege/15/ etc. I need to modify more settings that are not displayed in the main GUI. I couldn't find the information related to
Thanks in advance for your answer
Everyone's tags (1)
1 ACCEPTED SOLUTION
Silver
Re: Catalyst Express 500
There are 2 things you can try
1-- "http://IP_address/exec/cli" this will give you the cli interface of the switch
2-- If you want a GUI then download CNA on the computer that will give you more options to configure the switch. here is the link to download it :-
http://tools.cisco.com/support/downloads/go/PlatformList.x?sftType=Cisco+Network+Assistant&mdfid=280139109&treeName=Switches&mdfLevel=Model&url=null&modelName=Cisco+Catalyst+Express+500-24LC+Switch&isPlatform=N&treeMdfId=268438038&modifmdfid=null&imn...
Varun
Silver
Varun
Dear Varun:
     Thank you so much for your helpful tips, I am going to apply these advanced features with this option abled.
Kind Regards!!
Antonio Moreno
386
