Webcast-Catalyst9k
Catalyst IOS link?
Is there a place on cisco.com where I can find info about switch IOS's. The main "IOS" link only references the router images.
Thanks!
1 ACCEPTED SOLUTION
Re: Catalyst IOS link?
Chris,
You can go to software centre and chose switch software (CCO required)
http://www.cisco.com/public/sw-center/
HTH, rate if it does
Narayan
1 REPLY
Chris,
Narayan
101
