catalyst switch port configure - allow only machines which use dhcp
it is possible to let cat3750 or 2960 ports which only allow machine on network which it use dhcp, not static ip? if so, how to configure it?
any comments will be apprecaited
thanks in advance
julxu
2 ACCEPTED SOLUTIONS
I saw that you are asking also about configuration :
Let's supose that your hosts are on vlan 99.
Enable dhcp snooping on vlan99
ip dhcp snooping
ip dhcp snooping vlan 99
You should permit DHCP offer from the server , this configuration should be made on the port towards the DHCP server :
interface gi0/0
ip dhcp snooping trust
You should not enable ARP inspection before you have dhcp snooping table populated , because DAI will drop the packets.
You can check the DHCP snooping table using : show ip dhcp snooping bindings
Enable ARP insplection on vlan 99
ip arp inspection vlan 99
Also you will need to trust ( not use ARP inspection ) on the trunk ports.
interface gi2/3
ip arp inspection trust
Dan
You have enabled DHCP snooping for vlan 99 and DAI for 96. DAI should be also for 99. Typo ?
  ip arp inspection vlan 96
For those ports that have hosts with static IP assign you should configure one of those two
   1 ) ip arp inspection trust - it will disable DAI on that port.
   2) Use static bindings for DAI :
                       (global) arp access-list VLAN99
                                 permit ip host x.x.x.x mac host h.h.h
                       (global) ip arp inspection filter VLAN99 vlan 99
This is also your case. Gi1/1 is connected to another switch. You must configure ip arp inspection on this port.
Dan
Bronze
Re: catalyst switch port configure - allow only machines which u
Have a read thru this
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_55_se/configuration/guide/swdhcp82.html
Also you can use port-security on the switch port, to allow only 1 or a certain number of mac-addresses to associate with that port.
Hope it helps
Eugen
Hall of Fame Super Gold
Not possible, as far as I'm aware, without the use of NAP/NAC.
Hi ,
I belive that a good solution is DAI (arp inspection ) + DHCP snooping.
Dan
ip dhcp snooping
interface gi0/0
interface gi2/3
Dan
Dan,
Actually, the DHCP Snooping + IP Source Guard would do the trick here. The DAI is a nice feature but it does not really prevent a station from having a static IP address and accessing the network. Using the IPSG, on the other hand, will prevent a station from communicating if it is not assigned an IP address via DHCP.
The IPSG is configured fairly easily: after configuring the DHCP Snooping as you suggested, the IPSG is configured on a per-interface basis using the ip verify source command.
Best regards,
Peter
Hi Peter,
As far as I know , DAI permits frames on non trusted ports based on DHCP snooping database.
So if you have DAI + DHCP snooping enabled on VLAN, and a host in that vlan has the IP configured staticaly, DAI will drop every frame from that host. And in order to make this host function properly with static ip , a arp inpection filter should be configured.
As for a host that gets its IP via DHCP, the same vlan as the upper host, DHCP snooping database having its mac/ip in the database (dhcp server has already send its offer ), DAI will permit its frames thru the port.
You are saying that this is not the case ?
Kind regards,
Dan
Great thanks for all help. I have tried Dan's method by :
on router configuration
   ip dhcp snooping
   interface GigbitEthernet1/1
     description to test switch
     swtchport
     switchport mode trunk
on test switch
   ip dhcp snooping
      description to route
   interface GigbitEthernet0/1
      description test vista
       switchport access vlan 99
       switchport mode access
       switchport voice vlan 199
I can get dhcp traffic, both to/from server. but, I can not do anything, all other traffic be band. error on test switch:
%SW_DAI_4-DHCP_SNOOPING_DENY: 2 Invalid ARPs (Res) on G1/1, vlan99 ......
the messages has two ARP, another one is a static ip. if I take ip arp inspection vlan99 off, I can get traffic.
Please advice
Many Regards
Julxu
Dan
883
