01-21-2016 04:05 AM - edited 03-08-2019 03:29 AM
I need to know whether the Cisco Catalyst switch 3650 24 PoE+ 2x10G will work with an existing Aruba wireless controller or are there any compatibility issues within the same network.
01-21-2016 05:05 AM
Hey that will work fine my whole network is Cisco in terms of switches/routers etc but our wireless global network is all Aruba 3600s , there fully interoperable
01-21-2016 07:04 AM
Thank you for your comments. I think I need to be a little more specific.
I am trying to use the Catalyst 3650 switch as a wireless controller running AIR-CAP1602I-E-K9 Access Points in addition to the Aruba wireless controller system on the same subnet. Will this work and if so how?
Many Thanks
01-23-2016 06:47 AM
What exactly are you trying to achieve? I don't see why the two controllers care as long as their AP's know how to find their respective controller.
01-24-2016 05:38 AM
Dear ,
Access point will fine wlc on switch but i don't know it can work with aruba wlc or not , and you must connect Access point directly to core switch
so it can join wlc on switch
br,
mohamed fawzy
