Webcast-Catalyst9k
Catos ether-channel configuration/ adding another ports into it?
Greetings all,
I'm not so skilled in catos configuration so it would be really great if anybody can write his/her opinion about my configuration as I dont have any oportunity to test it before implementation.
My task is to upgrade existing port channel with adding another 2 ports between two 6500 switches sw1 & sw2.
Existing configuration/portchannel:
SW1:
set port channel 5/2,6/2 3
set vlan 999  5/2, 6/2
clear trunk 5/2  1-165,167-4094
set trunk 5/2  on dot1q 166
clear trunk 6/1  1-165,167-4094
set trunk 6/1  on dot1q 166
set spantree portcost    5/2  200
set spantree portcost    6/2  200
set port channel 5/2 mode desirable silent
set port channel 6/2 mode desirable silent
SW2:
I read: When you assign ports to an existing admin group, the original ports associated with the admin group will move to an automatically picked new admin group. You cannot add ports to the same admin group.
So I chose to create also new admin group. Ports to add 8/44 & 9/44.
Proposed configuration:
SW1:
set port enable 8/44
set port enable 9/44
set port channel all distribution ip both
set vlan 999 8/44
set vlan 999 9/44
clear trunk 8/44  1-165,167-4094
set trunk 8/44  on dot1q 166
clear trunk 9/44  1-165,167-4094
set trunk 9/44  on dot1q 166
set udld enable 5/2
set udld enable 8/44
set udld enable 6/2
set udld enable 9/44
set spantree portcost 8/44 200
set spantree portcost 9/44 200
set port channel 5/2,6/2,8/44,9/44 5
set port channel 5/2,6/2,8/44,9/44 mode desirable silent
SW2:
set vlan 999 8/44
set vlan 999 9/44
set udld enable 5/2
set udld enable 6/2
Questions/concerns:
-My biggest concern is if the assignment to admin group 5 will work. Not sure how the catos behave once ports are assigned to admin group 3.
-And also if port channel could be created using ports on those cards.
sh port capabilities - on all ports
Channel                     yes
@@ HW:
(Switches are similar):
WS-C6509-E Software, Version NmpSW: 8.5(5)
Copyright (c) 1995-2006 by Cisco Systems
NMP S/W compiled on Jun 14 2006, 10:28:59
System Bootstrap Version: 12.2
System Boot Image File is 'bootdisk:cat6000-sup32pfc3k9.8-5-5.bin'
System Configuration register is 0x2102
Hardware Version: 1.2  Model: WS-C6509-E  Serial #: SMG1017NGHB
@@ USED CARDS:
NAME: "5", DESCR: "1000BaseX Supervisor 9 port WS-SUP32-GE-3B Rev. 4.2"
PID: WS-SUP32-GE-3B    , VID: V02, SN: SAL1018LRZU
NAME: "submodule 5/1", DESCR: "L3 Switching Engine III"
PID: WS-F6K-PFC3B      , VID:    , SN: SAL1018LZ37
NAME: "6", DESCR: "1000BaseX Supervisor 9 port WS-SUP32-GE-3B Rev. 4.7"
PID: WS-SUP32-GE-3B    , VID: V08, SN: SAL1407B4EZ
NAME: "submodule 6/1", DESCR: "L3 Switching Engine III"
PID: WS-F6K-PFC3B      , VID:    , SN: SAL1407B61K
NAME: "8", DESCR: "10/100/1000BaseT Ethernet 48 port WS-X6148A-GE-TX Rev. 1.4"
PID: WS-X6148A-GE-TX   , VID: V02, SN: SAL1020NDWA
NAME: "9", DESCR: "10/100/1000BaseT Ethernet 48 port WS-X6148A-GE-TX Rev. 1.4"
PID: WS-X6148A-GE-TX   , VID: V02, SN: SAL1020NDUY
200
