01-29-2009 02:51 PM - edited 03-06-2019 03:45 AM
During a CatOS to IOS conversion we experienced a power failure - :(
After we recovered from the power failure, the switch boots into the SP rommon mode.
Issuing the "boot" command (rommon> boot) the switch boots to the RP mode, reads the new IOS image and all seems fine.
ROUTER# show version reveals the RP config-register is 0x2102.
ROUTER# remote command switch show bootvar reveals the switch config-register is 0x8002.
I know the SP config-register should be 0x2102.
Upon booting, the new IOS file is read but our saved config file is ALWAYS ignored.
I have tried to reset the SP config-register with no luck.
Anyone know how to change the SP config-register settings from SP rommon, RP rommon, router# or other?
Thanks for ANY help
Frank
01-29-2009 03:11 PM
Did you try:
conf t
config-register 0x2102
wr mem
remote command switch show version >> The wrm mem from RP should overwrite the SP.
01-29-2009 03:37 PM
Hey bosalaza, Thanks.
My steps in order
ROUTER#(config) config-register 0x2102
ROUTER#(config) host VASSR0014
VASSR0014#(config) boot system flash sup-bootflash:--IOS file name--
VASSR0014# wr
VASSR0014# reload
Upon reloading
router#
SP config-register still set to 0x8002
If I re-power the box, the boot process stops at SP rommon.
At this point I can issue confreg and change the SP boot parameters but don't know how to set them to 0x2102 as this is NOT an option. The SP rommon confreg is menu driven and 0x2102 is NOT one of the options.
If I issue the rommon boot command, the SP loads with a LOT of hex errors messages, then switches to the RP and loads the new IOS file found on the sup-bootflash and defaults to a clean config.
Any other ideas?
THANKS AGAIN!!!
01-29-2009 05:06 PM
Sorry I mistook your issue for something else. Here is how to change the SP rommon through the menu driven process.
You can change the confreg for the SP from the ROMMON mode. Reload, issue a break and go to rommon.
then :
rommon 3 > priv
You now have access to the full set of monitor commands.
Warning: some commands will allow you to destroy your
configuration and/or system images and could render
the machine unbootable.
rommon 5 > confreg
Configuration Summary
(Virtual Configuration Register: 0x2)
enabled are:
[ 0 ] break/abort has effect
[ 1 ] console baud: 9600
boot: ...... image specified by the boot system commands or default to: cisco2-Cat6k-Sup32
do you wish to change the configuration? y/n [n]: y
enable "diagnostic mode"? y/n [n]:
enable "use net in IP bcast address"? y/n [n]:
enable "load rom after netboot fails"? y/n [n]:
enable "use all zero broadcast"? y/n [n]:
disable "break/abort has effect"? y/n [n]:
enable "ignore system config info"? y/n [n]:
change console baud rate? y/n [n]:
change the boot characteristics? y/n [n]: y <<<<<<<<<
enter to boot:
0 = ROM Monitor
1 = the boot helper image
2-15 = boot system
[2]: 2 <<<<<<<<<<<<<<
enabled are:
do you wish to change the configuration? y/n [n]: n
rommon 6 > sync
rommon 7 > reset
Resetting .......
HTH,
Mark
01-30-2009 11:04 AM
Hi Mark,
THANKS for the support
Details of hardware
Single sup720-3B with PFC3B
Started the system with a power on, followed your steps from the SP rommon 1 (priv, confreg etc.)
No error messages received from any typed-in commands. Once in the ROUTER#, I checked the switch config and still set to 0x8002. The router config-register is 0x2102.
I set the host name, boot flash and write.
VASSROO14# reset
System restarted, passed through the SP and onto the RP. ALL settings were saved from previous write mem.
I checked the switch config-register and still set to 0x8002, router was still 0x2102.
I reset multiple times with the exact same outcome.
I then repowered the box and ended back at the rommon 1 prompt of the SP.
I issued the boot command and the system reloaded as normal but this time with a clean config ROUTER#
Issued a remote command to check the switch config-register, still set to 0x8002, router was set to 0x2102
Turns out as long as I do not repower the box everything is fine and works as expected.
If I repower the box, I ALWAYS end up at the rommon 1 prompt.
If I issue the reset command this is what I see:
System Bootstrap, Version 8.4(2) Release
Copyright (c) 1994-2005 by cisco Systems, Inc.
Testing lower main memory - data equals address
Testing lower main memory - checkerboard
Testing lower main memory - inverse checkerboard
Clearing lower memory for cache initialization
Clearing bss
Clearing autoboot state machine
melody_present_reg: 1st read w/ 0x4d8
melody_present_reg: 2nd read w/ 0x4d8, reversed: 0xfb27
Bootdisk adapter not detected, use bootflash instead.
Reading monitor variables from NVRAM
Reset reason for CPU board 0xffff , BaseBoard 0x280ffff, display 0x20000System Reset by Software.
Enabling interrupts
Initializing TLB
Initializing cache
Initializing required TLB entries
Initializing main memory
Sizing NVRAM
Initializing PCMCIA controller
Exiting init
Cat6k-Sup720/SP processor with 524288 Kbytes of main memory
Autoboot executing command: "boot bootflash:s72033-adventerprisek9-mz.122-33.SXI.bin"
Loading image, please wait ...
Stack pointer : 0x8FFFFF80
monstack : 0x800FFFC0
monra : 0xBFC26794
edata : 0x801082A0
magic : 0xFEEDFACE
memsize : 0x10000000
uncomp_size : 0x03BD0400
comp_checksum : 0x6B552955
uncomp_checksum : 0x6B552955
CZIP_MEM_BASE : 0x80000000
_end : 0x801082C0
Self extracting the image...
IOS compressed src copy is : 0x801082B4
czip + IOS tar size is :0x00BFA374
czip + IOS Tar image is now :0x801084B4
cptr is now :0x801083C0
IOS compressed dest copy is : 0x801083C0
[OK]
image_entry :0x80100000
__start : 0x80100000
tar_avail_size is now :0x02FD5E00
Tar image address is : 0x80D027C0
tar_size is : 0x02FD5A00
cpu type : 0x00000019
image_info.entry_point = 0x80100000
image_info.section_count = 0x00000004
image_info.monstack = 0x800FFFC0
image_info.monra = 0xBFC26794
image_info.param0 = 0x00000002
image_info.param1 = 0x00000000
image_info.param2 = 0x80006300
image_info.param3 = 0x80100000
image_info.reg_k0 = 0x80D027C0
image_info.reg_k1 = 0x02FD5A00
01-30-2009 11:06 AM
data_size in czip : 0x00001000
bss end of IOS is : 0x8418FD30
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, s72033_sp Software (s72033_sp-ADVENTERPRISEK9-M), Version 12.2(33)SXI, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 07-Nov-08 04:29 by prod_rel_team
Image text-base: 0x40101328, data-base: 0x421BCD70
*Jan 1 00:06:21.127: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Jan 1 00:06:19.635: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor for this switch
Firmware compiled 24-Oct-08 15:13 by integ Build [100]
*Jan 1 00:06:21.127: %OIR-6-CONSOLE: Changing console ownership to route processor
System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
Copyright (c) 2005 by cisco Systems, Inc.
Cat6k-Sup720/RP platform with 524288 Kbytes of main memory
Download Start
Download Completed! Booting the image.
Self decompressing the image : ########################################################################################################################################################################################################################################################################################################################################################################################## [OK]
cisco Systems, Inc.
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9-M), Version 12.2(33)SXI, RELEASE SOFTWARE (fc2)
Compiled Fri 07-Nov-08 04:01 by prod_rel_team
Image text-base: 0x40101328, data-base: 0x445503F0
01-30-2009 11:06 AM
VASSR0014#sh boot
BOOT variable =
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Standby is not up.
VASSR0014#remote command switch sh boot
BOOT variable = bootflash:s72033-adventerprisek9-mz.122-33.SXI.bin,1;
Configuration register is 0x8002
VASSR0014#conf t
Enter configuration commands, one per line. End with CNTL/Z.
VASSR0014(config)#boot system flash sup
*Mar 1 00:00:02.315: DaughterBoard (Centralized Forwarding Card)
Jan 1 00:07:40.559: %SYS-CFC1-5-RESTART: System restarted --
Cisco IOS Software, c6lc2 Software (c6lc2-SP-M), Version 12.2(33)SXI, RELEASE SOFTWARE (fc2)
Compiled Fri 07-Nov-08 04:00 by prod_rel_team
Jan 1 00:07:40.563: CFC1: Currently running ROMMON from S (Gold) region
VASSR0014(config)#
*Jan 1 00:07:43.443: %DIAG-SP-6-RUN_MINIMUM: Module 1: Running Minimal Diagnostics...no boot system flash sup
VASSR0014(config)#
*Jan 1 00:07:52.119: %DIAG-SP-6-DIAG_OK: Module 1: Passed Online Diagnostics
VASSR0014(config)#
VASSR0014(config)#
*Jan 1 00:07:53.503: %OIR-SP-6-INSCARD: Card inserted in slot 1, interfaces are now online
VASSR0014(config)#
VASSR0014(config)#$ flash bootflash:s72033-adventerprisek9-mz.122-33.SXI.bin
VASSR0014(config)#end
VASSR0014#wr
Building configuration...
*Jan 1 00:08:25.471: %SYS-5-CONFIG_I: Configured from console by console[OK]
VASSR0014#
VASSR0014#
VASSR0014#sh boot
BOOT variable = sup-bootflash:s72033-adventerprisek9-mz.122-33.SXI.bin,1;bootflash:s72033-adventerprisek9-mz.122-33.SXI.bin,1;
Standby is not up.
01-29-2009 03:15 PM
Try rebooting the other supervisor and change the config register in rommon. When you are in rommon type "confreg 0x2102" and hit enter and then type "reset" That will reboot the supervisor.
HTH,
Mark
01-29-2009 04:16 PM
Does the switch have dual sup? When you wr mem and reload and you have dual sup the standby takes over and it might not have sync with the active yet, which is probably why it did not change the config-register on SP. BTW, when you changes the config-register from the RP, I di dnot see if the SP's config-register actually changed or it shoudl say it will be "2102" on next reload. Did you verify that?
01-29-2009 04:27 PM
Here is a capture of what I am trying to explain that wr mem from rp would sync the SP's config-register:
***FROM RP's show version***
Router#sh ver
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF5, RLEASE SOFTWARE (fc3)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Sat 08-Jul-06 03:22 by kellythw
Image text-base: 0x40101040, data-base: 0x42D88000
Configuration register is 0x2102 >> RP is 2102
Router#
***REMOTE COMMAND SWITCH***
Router#remote command switch show ver
IOS (tm) s72033_sp Software (s72033_sp-IPSERVICESK9-M), Version 12.2(18)SXF5, RLEASE SOFTWARE (fc3) >>> This tells me I'm looking at SP see the file name "s72033_sp.."
Compiled Sat 08-Jul-06 03:28 by kellythw
Image text-base: 0x40101040, data-base: 0x41450000
ROM: System Bootstrap, Version 8.1(3)
BOOTLDR: s72033_sp Software (s72033_sp-IPSERVICESK9-M), Version 12.2(18)SXF5, RLEASE SOFTWARE (fc3)
65536K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x0 >> SP's config-register is 0x0
Router(config)#config-register 0x2102
Router(config)#end
Router#wr mem
[OK]
***AFTER WR MEM the following shows that SP have synced with RP***
IOS (tm) s72033_sp Software (s72033_sp-IPSERVICESK9-M), Version 12.2(18)SXF5, RELEASE SOFTWARE (fc3)
BOOTLDR: s72033_sp Software (s72033_sp-IPSERVICESK9-M), Version 12.2(18)SXF5, RELEASE SOFTWARE (fc3)
Configuration register is 0x0 (will be 0x2102 at next reload)
Router#
