CatOS to IOS on 6509
I need to convert our config on the 6509 from CatOS to IOS. Have anyone used the Cisco EDI CatOS to IOS configuration Tool? Is it worth using it or should I just do this conversion manually? Any suggestions what to look out for would be greatly appreciated. I have never done this before so any advise would be great.
WS-C6509 Software, Version NmpSW: 8.3(4)
System Bootstrap Version: 8.1(3)
System Boot Image File is 'bootflash:cat6000-sup720k9.8-3-4.bin'
cat6509> (enable) sh module
Mod Slot Ports Module-Type Model Sub Status
1 1 24 1000BaseX Ethernet WS-X6724-SFP yes ok
2 2 48 10/100BaseTX Ethernet WS-X6148-45AF yes ok
3 3 48 10/100/1000BaseT Ethernet WS-X6548-GE-TX yes ok
5 5 2 1000BaseX Supervisor WS-SUP720-BASE yes ok
15 5 1 Multilayer Switch Feature WS-SUP720 no ok
6 6 2 1000BaseX Supervisor WS-SUP720-BASE yes standby
16 6 1 Multilayer Switch Feature WS-SUP720 no standby
7 7 8 Network Analysis Module WS-SVC-NAM-2 no ok
8 8 8 Intrusion Detection Mod WS-SVC-IDSM-2 yes ok
9 9 6 Firewall Module WS-SVC-FWM-1 no ok
1 REPLY
Re: CatOS to IOS on 6509
I have converted 16 6509's using the manual documentation, and in the beginning had problems, mostly because I went out of sequeunce by reading to far ahead. Then configured each module. You have several modules installed that I didn't have, so it might be more time consuming and open to errors using the manual approach.
I realize this might not be the answer your seeking, but I found for our configuration, manual was better, and longest conversion took 30 minutes.
Dave
316
