Webcast-Catalyst9k
CatOS
To whom it may concern,
For CatOS, what's the command to change a port from trunk port to access port on VLAN 50??
On Native IOS:
switchport access vlan 50
switchport mode access
But what's the command on CatOS??
Cheers,
Hunt
Re: CatOS
set vlan 50 0/15
Here i have assumed 0/15 is your port number.
Re: CatOS
i did do that.... but when i connect a laptop to 0/15, it still show up as trunk on 'show port'.
Re: CatOS
Hi Hunt,
You can use
set port host
which will set your port to access mode and perform portfast. After doing this , you can assign the correct vlan to your port.
Hope to help,
Kerem
Purple
Re: CatOS
You can also use set trunk slot/port off " I believe. This makes it a access port.
130
