CBWFW-Service-policy out on Ethernet-subinterfaces
Hi need solution where I can assign output service-policy with CBWFQ/LLQ on to a Ethernet-Subinterface (dot1q-encapsulated)
Its definitifely not supported on
2800,3800,7200
Does anybody know if it is supported on one of the following platforms/interfaces
ASR ??
7600 ES20 ??
7600 SIP SPA ??
policy-map QOS-Policy-WAN-2000kbps
description QOS-Policy for 2000Kbps-PVCs
class QOS-Class-Realtime
priority percent 25
class QOS-Class-Platinum
bandwidth percent 15
class QOS-Class-Gold
bandwidth percent 5
class QOS-Class-Silver
bandwidth percent 10
class QOS-Class-Bronze
bandwidth percent 25
class class-default
DBE-LINZ-DL08(config)#int gig 0/3
DBE-LINZ-DL08(config-if)#int gig 0/3.100
DBE-LINZ-DL08(config-subif)#enc
DBE-LINZ-DL08(config-subif)#encapsulation do
DBE-LINZ-DL08(config-subif)#encapsulation dot1Q 100
DBE-LINZ-DL08(config-subif)#do term mon
DBE-LINZ-DL08(config-subif)#max-reserved-bandwidth 90
% Invalid input detected at '^' marker.
DBE-LINZ-DL08(config-subif)#service-policy output QOS-Policy-WAN-2000kbps
CBWFQ : Not supported on subinterfaces
Re: CBWFW-Service-policy out on Ethernet-subinterfaces
AFAIK - no router supports QoS on sub-interfaces, I might be wrong.
You might be better to configure the QoS on the switch that the router connects to on the inbound?
Bad news , I would need it for a Hub-router where I connect to Metro-Ethernet-Provider which delivers us a lot of VLANs(dot1q-tagged) via on GE (for p2p-connection to remote sites) a we have to do different Queueing-settings for the different VLANs.
Hubert
Ahh OK no I understand - I have come across this before in a different circumstance. I had to limit the amount of traffic going into a GRE tunnel, that also does not support CBWFQ directly......but the work around I found was to use a nested policy - which shaped the traffic, based on CBWFQ!!! which did work - you might want to try this, below is a sample config:-
policy-map CBWFQ
description *** Class-Based Weighted Fair Queueing ***
class eigrp
priority 8
class voice-audio
priority 600
class voice-keepalive
priority 64
class voice-signaling
bandwidth 32
class icmp
bandwidth 8
class telnet
bandwidth 64
class class-default
fair-queue
random-detect dscp-based
policy-map Shape-Tunnel
description *** Outbound Shaping into GRE Tunnel ***
class class-default
shape average 2048000
service-policy CBWFQ
HTH>
Hi thnaks that workes,
i already did the sam config on some ethernetinterface which are connected to DSL, but not on subinterfaces
Hubert
np - glad to help.
Super Bronze
It might work if you use a parent shaper.
policy-map QOS-Policy-WparentAN-2000kbps_parent
class class-defuault
shape 2000000
service-policy QOS-Policy-WAN-2000kbps
int g 0/3
service-policy output QOS-Policy-WparentAN-2000kbps_parent
483
