Community Member
CCIE R&S question
What are the differences betwenn LACP and PAGP ? I know that LACP is a IEEE protocol but other than that they seem to be the same.
Can anybody please point me to a document that would help me to understand the differences ?
Thank you
Cristian
bjw Silver
Silver
Re: CCIE R&S question
Community Member
Thank you I had read this when I posted the message.
Couldn't understand a some of the things explained there
LACP system priority- couldn't understand the way it is used
LACP port priority- this is OK I understand
LACP administrative key- this is not, I don't understand this
Purple
They are the same , lacp is the IEEE standard and pagp is cisco proprietary etherchannel protocol . I believe the IEEE standard was even derived from the cisco's version . The only real differences are the syntaxes on the interfaces , the terminalogy is slightly different .
The one big advantage LACP has over PAGP is the interoperability with the other vendor switches. PAGP, being Cisco Proprietary, cannot aggregate channels with other vendor switches.
Sundar
Community Member
the priority mechanisms above mentioned do not exist in PAGP. So that may be an important differece but as I wrote above I do not undersatand the way it works.
Community Member
http://www.cisco.com/warp/public/473/126.html is a good place to start. It covers both IOS and CatOS basics for both protocols. Use the examples to configure a pair of switches and then watch your debugs. Lab it out! Best, ~M
166
