CCNA expaires
My CCNA Ceritifiation eligibility expaired on Apr20th-07, wil it possible to take CCNP certifiation without doing CCNA again , plz help on this.
Bronze
Re: CCNA expaires
No, unfortunately you have to recertify your CCNA. You can do the CCNP test , but have to do the CCNA to get the CCNP certification.
Bjornarsb
Re: CCNA expaires
Hi ,
you mean to say no need of taking CCNA certification again , i can straight away do the certification like CCNP and so on.
pleae clear me on this .
Re: CCNA expaires
Cisco will not stop you taking CCNP tests. You can take any test and pass all your CCNP modules. But Cisco will not issue you a CCNP certificate unless you meet the pre-requisite which is CCNA.
You will need to pass CCNA if you need CCNP certificate.
Hope this helps
regards
Shaheen
122
