Community Member
CDP: Disable
Is it possible to disable cdp under an SVI on a Catalyst 6500 switch. tried running the command but still no sucess. CDP is globally enabled.
interface vlan 100
no cdp run
Bronze
Re: CDP: Disable
I have not tried it but isn't the command to disable cdp under an interface:
no cdp en
regards,
Purple
Re: CDP: Disable
CDP is not a layer 3 function so you would have to disable it on the port interfaces.
Hall of Fame Super Gold
Re: CDP: Disable
The "no cdp run" is for Global configuration only (turns off CDP to the appliance).
You can over-ride this command by going into the interface and do the "no cdp enable".
For example.
config t
no cdp run < -- Turns OFF CDP to the appliance.
interface FastEthernet 2/12
cdp enable < --- Enable CDP to this AND ONLY this interface.
Does this help?
Bronze
Re: CDP: Disable
Hi Leo,
exactly my point in my posting earlier that he ought to use no cdp en under the interface.
regards,
252
