11-18-2013 06:42 AM - edited 03-07-2019 04:39 PM
Hi All,
I'm practicing for my CCNA. Now i'm analysing the CDP.
My topology has a router and 2 switches as shows below.
Here i configured the Fa0/2 ports on both switches to be half-duplex. But the "show cdp entry *" is showing that the port is operating in an full duplex mode.
Here is the confirmation that i configured fa0/2 on both switches as half-duplex:
Truncated output from switch0:
switch0#show interfaces fastEthernet 0/2
FastEthernet0/2 is up, line protocol is up (connected)
Hardware is Lance, address is 00d0.ba12.5102 (bia 00d0.ba12.5102)
BW 100000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Half-duplex, 100Mb/s
input flow-control is off, output flow-control is off
Truncated output from switch1:
switch1#show interfaces fastEthernet 0/2
Hardware is Lance, address is 00e0.8f36.6502 (bia 00e0.8f36.6502)
Here is the output from switch0 for "show cdp entry *" command:
Truncated o/p:
switch0#show cdp entry *
Device ID: switch1
Entry address(es):
IP address : 10.11.12.253
Platform: cisco 2960, Capabilities: Switch
Interface: FastEthernet0/2, Port ID (outgoing port): FastEthernet0/2
Holdtime: 144
Version :
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(25)FX, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Wed 12-Oct-05 22:05 by pt_team
advertisement version: 2
Duplex: full //whereas it has to be half //
Thanks in advance for help.
Chandu
Solved! Go to Solution.
11-18-2013 01:51 PM
Chandu,
That's one of the biggest problems with simulators when it comes to discrepancies.
11-19-2013 01:15 PM
In real switches, "sh cdp neighbor" will give you good details better than simulators. Even old switches like 2900XL/3500XL are very good studying tools for your certification. You can get working 2900XL/3500XL cheaply from e-bay.
11-18-2013 01:51 PM
Chandu,
11-18-2013 08:58 PM
Thanks Leo.
But can you let me know whose duplex settings will "show cdp entry * " command shows.
Here in this case will it shows the duplex setting of switch0's interface or switch1's interface ?
Chandu
11-19-2013 01:15 PM
11-19-2013 09:30 PM
Will there be any question regarding CDP in the ccna exam ?
11-19-2013 11:51 PM
Depends on your "luck". You will get any random questions from the Cisco database.
11-20-2013 02:49 AM
Finally, will i pass CCNA with PT ?
Because i cannot offer a real equipment.
Chandu
11-20-2013 06:25 AM
Yes, you can pass CCNA R/S with PT. There's already a version 6 released which includes ISR G2 routers running IOS 15.0.
I would stay away from "XL" switches as they're limited with commands that it supports.
11-21-2013 02:13 AM
Thanks for you feedback.
Chandu
