CE 500 remove configuration
Just bought two CE 500 and found out that one had been configured (the second CE 500 had the same boot sequence after i configured the first swith). I configured the first one and found no problem and able to assign IP, however on the second switch the setup led did not blink. Is there a way to remove the configuration or erase the setup IP? i have been searching the Cisco web site and could not find how to remove old config.
thanks!
1 REPLY
Re: CE 500 remove configuration
Add and remove users with the ?user add? and ?user delete? commands.
Try:
http://www.cisco.com/en/US/products/hw/contnetw/ps761/prod_configuration_examples_list.html
283
