CEF and RIB???
I want to know about what is RIB and How its work in routing???
If I want insert some specific entry in RIB how I can.
Please help and share the tips...
  • LAN Switching and Routing
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: CEF and RIB???
abhi-adte wrote:
ooh it means RIB table and Routing table is same??
Yes.
Re: CEF and RIB???
Abhinay,
A lot of reading and show commands on the IOS has to be done from your side for this.
Its better to
1. Read the concepts
2. Try out on the IOS
3. Ask questions
RIB is the Routing information base, another jargon for Routing table.
CEF is an efficient way of routing packets across a router and is very scalable and can be called switching at Layer 3
Please refer to http://articles.techrepublic.com.com/5100-10878_11-6146827.html for an intro.
Re: CEF and RIB???
The RIB is the routing table. Dynamic routing protocols will insert routes into the RIB themselves. If you wanted to insert a specific entry into the RIB then configure a static route eg.
ip route 192.168.5.0 255.255.255.0
Jon
Re: CEF and RIB???
Re: CEF and RIB???
Yes.
Re: CEF and RIB???
hi abhi,
i guess RIB and Routing table are same thing.
261
