03-04-2014 07:06 PM - edited 03-07-2019 06:32 PM
Hello All,
We are planning to turn on policy based routing (PBR) on one of our Cisco ASR 1001, on which average resource utilization is around 50%. I came across document that says flow switching will be disabled on the interface on which PBR is enabled, but does not say anything about effects on CEF switching and also i could not find in any other supporting document:-
Comment on the document
" ip policy route-map command disables fast switching of all packets arriving on this interface."
Link where i found the above comment:-
I am interested to know if there would any underline effect to CEF switching after enabling PBR on the Cisco ASR 1001 interface and packet would be hardware switched instead of process-switched. Also if there is a supporting document that says it would be helpful in supporting this claim on Cisco ASR 1001,
We are running image asr1001-universalk9.03.03.01.S.151-2.S1.bin on the router with advipservices license
Kumar Mittal
03-06-2014 07:07 PM
Hello
Got it tested in lab. Cisco ASR 1001 supports CEF enabled PBR. Even though the flow switching is disabled on the interface after enabling command ip policy route-map, but there is no effect on CEF.
Kumar
09-01-2016 08:08 AM
According to the "Network Security Features for Cisco ASR 1000 Series Routers" PBR is supported in hardware:
The Cisco ASR 1000 Series Router is the industry’s first highly scalable WAN and Internet edge router platform that delivers embedded hardware acceleration for Cisco IOS® Software services such as VPN, firewall, Network-Based Application Recognition (NBAR), NetFlow, quality of service (QoS), IP Multicast, access control lists (ACLs), Reverse Path Forwarding (RPF), and Policy-Based Routing (PBR), without the need for separate service blades.
Document is found here:
http://www.cisco.com/c/en/us/products/collateral/application-networking-services/wide-area-application-services-waas-software/data_sheet__network_security_features_for_cisco_asr_1000_series_routers.html
