CEF Load Sharing
Yongbing WU
Is per-source CEF load sharing supported or will it be supported in IOS? Thanks.
Reza Sharifi
If you do not want to use the universal algorithm, then you can use this command to change it.
ip cef load-sharing algorithm
http://www.cisco.com/en/US/docs/ios/ipswitch/command/reference/isw_i1.html#wp1011833
Reza
Looks like per-source CEF load sharing is not supported yet. Just want to know if Cisco has a plan to add per-source CEF load sharing. PBR (source based routing) load sharing can achieve similar goal in some case, but per-source CEF load sharing is NOT replaceable.
