01-31-2008 06:04 AM - edited 03-05-2019 08:51 PM
Hello everybody;
I have enabled CEF with per-destination load balancing on 6506 MSFC2 with PFC2.
I see an unexpected behaviour. There are 5000 entries in the routing table and 4 available next-hops.
I see an unequal distribution of traffic between the links:
Interface IHQ IQD OHQ OQD RXBS RXPS TXBS TXPS TRTL
* FastEthernet3/1 0 0 0 0 2137000 1250 129000 198 0
* FastEthernet3/2 0 0 0 4290 1985000 1380 12032000 3613 0
* FastEthernet3/4 0 0 0 0 1429000 1088 308000 489 0
* FastEthernet3/9 0 0 0 6764 1250000 949 9823000 2783 0
Why there are these big differencies?
Many thanks
Solved! Go to Solution.
01-31-2008 10:49 AM
6500 uses hardware switching, or MLS CEF to switch packets, not regular software CEF.
MLS CEF will do similar load-sharing as software CEF, except by default it will unequally share load when there is an even number of equal-cost paths.
If you want to change this behavior, configure 'mls ip cef load-sharing simple'
01-31-2008 10:49 AM
02-04-2008 04:14 AM
Hi William,
I've tried to apply ''mls ip cef load-sharing simple'' but it's non supported on my platform.
I've instead applied 'mls ip cef load-sharing full' and now load balancing works fine!!
Any suggestion about? What is the difference between the option 'simple' and 'full'?
Many thanks for your support
King Regards
