CFC and DFC card for 6500 - X67xx module
Hi Guys,
Q1:anybody knows what's the difference for followed daughter card of WS-X6748-GE-TX?
Q2:in which case I should choose these card and which one ?
( 1 ) WS-F6700-CFC
Catalyst 6500 Central Fwd Card for WS-X67xx modules
( 2 ) WS-F6700-DFC3B
Catalyst 6500 Dist Fwd Card, 256K Routes for WS-X67xx
( 3 ) WS-F6700-DFC3A
Catalyst 6500 Dist Fwd Card for WS-X67xx modules
( 4 ) WS-F6700-DFC3BXL
Catalyst 6500 Dist Fwd Card- 3BXL, for WS-X67xx
( 5 ) WS-F6700-DFC3C
( 6 ) WS-F6700-DFC3CXL
Catalyst 6500 Dist Fwd Card- 3CXL, for WS-X67xx
Thanks in advanced
1 ACCEPTED SOLUTION
Bronze
Re: CFC and DFC card for 6500 - X67xx module
From what I recall... The DFC should match the supervisor engine PFC (PFC3 BXL and DFC 3BXL, for example).
If you search on Cisco's site you can get a rundown of what the specifics are for each model. I would recommend no less than the 3BXL but it depends on what PFC you have on the SUP.
Bronze
Thanks avmabe, I was confirmed with Cisco Partner Help Online DFC card should match the supervisor engine module like what you explained.
The other thing I found out and confirmed with Cisco PHO is:
for some x67xx and x68xx latest 1/10G Ethernet line card, 6513 chassis only supports maximum 5 cards , that's why you can NOT select this type of card for slot 3-8 from Dynamic Configuration Tools.
This information not officially announced on any Cisco documentation.
Hello
See the following document Cisco "Catalyst 6500 Architecture White Paper" http://www.cisco.com/en/US/products/hw/switches/ps708/products_white_paper0900aecd80673385.shtml
hth
2765
