Community Member
Change 2980 switch password
Im not use to 2980 switches. How do I change the console, telnet and enable password?
Re: Change 2980 switch password
enable password:
conf t, enable password XXX
telnet password:
conf t
line vty 0 4
password YYY
Console password:
conf t
line con 0
password ZZZ
More details and config examples at:
http://www.cisco.com/en/US/docs/ios/security/configuration/guide/sec_cfg_sec_4cli_ps6017_TSD_Products_Configuration_Guide_Chapter.html#wp1112567
Bronze
2980 switches are CatOS switches :-)
set password
set enablepassword
Then you'll be prompted for old password which by factory default is and then you will be asked for the new password twice.
Silver
516
