12-11-2006 02:19 PM - edited 03-05-2019 01:17 PM
In CatOS there used to be a command "change sup" which would make the redundant supervisor module active. Does anyone know the equavilant command in IOS 12.2?
Solved! Go to Solution.
12-11-2006 02:45 PM
Hello roland,
did you try :
Router# redundancy force-switchover
Conducts a manual switchover to the redundant supervisor engine. The redundant supervisor engine becomes the new active supervisor engine running the new Cisco IOS image. The modules are reloaded and the module software is downloaded from the new active supervisor engine.
The old active supervisor engine reboots with the new image and becomes the redundant supervisor engine.
Hope this helps.. all the best. rate replies if found useful..
Raj
12-11-2006 02:45 PM
Hello roland,
did you try :
Raj
12-12-2006 10:58 PM
that worked great thanks!
