Community Member
Changing core routers using HSRP
All,
I am trying to find out the best method/approach for changing out our core routers. We run 2 3550 switches in a collapsed core model that are running HSRP and being used as our core routers. I am installing a stack of 4 3750G switches and would like to make this stack our core routers and decommision our existing 3550's. What would be the best approach for this, taking in mind that the virtual IP used by HSRP needs to be in play on the new stack as all our campus switches point to that IP as their gateway. We run 25 VLAN's that are being routed by the current 3550's.
1 REPLY
Super Bronze
Re: Changing core routers using HSRP
You didn't describe how you're wired, but perhaps you can replace one of the existing 3550s with the 3750G stack.
Insure one 3550 is the active gateway for all subnets. Then replace the non-active gateway 3550. Then make the 3750G stack the active gateway for all the subnets. Lastly, pull the remaining 3550.
116
