03-24-2014 07:59 AM - edited 03-07-2019 06:49 PM
We have purchase supervisor engine 8 for 4500 switch and we plan to make a change for existing supervisor engine 7.
Will the change mess up existing configuration? I need to make a change on central switch, so before I do it, I'd like to know about possible problems that may come up.
Thanks!
03-24-2014 09:29 AM
The configuration is stored on the supervisor module, so backup your config before swapping it out. You'll need to apply the backup to the new module.
03-24-2014 12:15 PM
OK, thanks :)
