Community Member
Changing the SUP720 on WS-C6506-E from slot 5 to slot 6
I have a Cisco CAT6K switch (WS-C6506-E) and a SUP 720 engine installed on the slot 5.
I would like to know whether this Supervisor Engine 720, currently on slot 5 be changed to slot 6 and if so, does it require any configuration change?
Nithin.
Hall of Fame Super Blue
Why do you want to do that ?
Jon
Community Member
Hi Jon,The CAT6K frequently
Hi Jon,
The CAT6K frequently goes into the ROMMON mode and as per the recommendation from the Cisco TAC, they asked to change the SUP Engine from slot 5 to slot 6, due to some Fabric Interconnect errors. So wanted to try this.
Nithin.
NithinOkay, that makes sense
Nithin
Okay, that makes sense.
You should be fine to move it and it shouldn't require any additional configuration.
Jon
Community Member
Thanks a lot Jon for your
Thanks a lot Jon for your reply.
Do you have any idea of, why the switch is going to the ROMMON mode automatically.
Is it because of the hardware problem or due to the software crashes..?
CAT6K-SW01#sh rom-monitor slot 6 rp
Region F1: INVALID
Region F2: INVALID
Currently running ROMMON from S (Gold) region
CAT6K-SW01#sh rom-monitor slot 6 sp
Region F1: INVALID
Region F2: INVALID
Please do share your thoughts.
Nithin
NithinDepends what you mean
Nithin
Depends what you mean by automatically.
If the switch is dropping into ROMMON when it is up and running then you have a problem.
If when you boot it up it goes to ROMMON it could just be that you haven't told it which IOS image to boot.
That would depend on two things -
1) the configuration register
and
2) the "boot system ..." command
Jon
Community Member
Jon,Automatic in the sense,
Jon,
Automatic in the sense, the switch would be running fine for some days and when we get a message that the network is down and when the switch is checked it will be in the ROMMON mode.
CAT6K-SW01#sh bootvar
BOOT variable = sup-bootdisk:,1;
CONFIG_FILE variable does not exist
BOOTLDR variable =
SPP-CAT6K-SW01#sh sup-bootdisk:
-#- --length-- -----date/time------ path
1     33554432 Apr 11 2011 09:03:30 +00:00 sea_console.dat
2     71094564 Apr 11 2011 09:06:34 +00:00 s72033-ipservicesk9-mz.122-33.SXI5.bin
Doubt, the RP is crashing and causing the switch to be in ROMMON mode.
Nithin.
NithinIf the switch is
Nithin
If the switch is dropping into ROMMON while up and running then yes it may well be worth trying the other slot to see if that fixes it.
Is that the main issue ie. you are not trying to get it simply to automatically reboot ?
Jon
I agree with Jon. I see an
I agree with Jon. I see an earlier note that you saw fabric errors, it would be worth to check in slot6.
If you can share the recent crashinfo file i  can take a look at it.
Also as a best practice set the boot variable(you dont have at the moment.)
Further to that you may please check SP config reg value too ensure that it is 2102.(if it is not, everytime it crashes, switch may go to rommon)
remote command switch sh ver
HTH,
Madhu.
Community Member
we had same issue on sup 720. We did  the following which resolved the issue.
once in rommon, set the config register and reset it.
rommon 1 >confreg 0x2102
Community Member
Hi Rakesh,The config-register
Hi Rakesh,
The config-register is already set to 0x2102.
Nithin.
Community Member
Hi Yes Though it is already
Hi Yes
Though it is already set, we need to manually do the command in the rommon.
Community Member
Oh ok. Sorry understood you
Oh ok. Sorry understood you question wrongly.
1)So say if you reload  the switch manually, will it come back up normally?
2)Can you please post # dir all file-systems (Cannot remember the exact command).
     to check if there is any crashinfo file in others.
Community Member
Hi Rakesh,Yes, if I reload
Hi Rakesh,
Yes, if I reload the switch, it comes up normally.
CAT6K-SW01#dir all-filesystems
Directory of system:/
    2  -r--           0                    <no date>  default-running-config
    3  dr-x           0                    <no date>  memory
    1  -rw-       20812                    <no date>  running-config
   13  dr-x           0                    <no date>  vfiles
No space information available
Directory of tmpsys:/
    6  drw-           0                    <no date>  eem_lib_system
    5  drw-           0                    <no date>  eem_lib_user
   37  -rw-           0                    <no date>  eem_pnt_0
   39  -rw-           0                    <no date>  eem_pnt_1
   57  -rw-           0                    <no date>  eem_pnt_10
   59  -rw-           0                    <no date>  eem_pnt_11
   61  -rw-           0                    <no date>  eem_pnt_12
   63  -rw-           0                    <no date>  eem_pnt_13
   65  -rw-           0                    <no date>  eem_pnt_14
   67  -rw-           0                    <no date>  eem_pnt_15
   41  -rw-           0                    <no date>  eem_pnt_2
   43  -rw-           0                    <no date>  eem_pnt_3
   45  -rw-           0                    <no date>  eem_pnt_4
   47  -rw-           0                    <no date>  eem_pnt_5
   49  -rw-           0                    <no date>  eem_pnt_6
   51  -rw-           0                    <no date>  eem_pnt_7
   53  -rw-           0                    <no date>  eem_pnt_8
   55  -rw-           0                    <no date>  eem_pnt_9
    4  drw-           0                    <no date>  eem_policy
    8  drw-           0                    <no date>  eem_pub
   36  -rw-           0                    <no date>  eem_rpc_0
   38  -rw-           0                    <no date>  eem_rpc_1
   56  -rw-           0                    <no date>  eem_rpc_10
   58  -rw-           0                    <no date>  eem_rpc_11
   60  -rw-           0                    <no date>  eem_rpc_12
   62  -rw-           0                    <no date>  eem_rpc_13
   64  -rw-           0                    <no date>  eem_rpc_14
   66  -rw-           0                    <no date>  eem_rpc_15
   40  -rw-           0                    <no date>  eem_rpc_2
   42  -rw-           0                    <no date>  eem_rpc_3
   44  -rw-           0                    <no date>  eem_rpc_4
   46  -rw-           0                    <no date>  eem_rpc_5
   48  -rw-           0                    <no date>  eem_rpc_6
   50  -rw-           0                    <no date>  eem_rpc_7
   52  -rw-           0                    <no date>  eem_rpc_8
   54  -rw-           0                    <no date>  eem_rpc_9
    7  drw-           0                    <no date>  eem_temp
    1  dr-x           0                    <no date>  lib
Directory of flexwan-fpd:/
    0  dr--   <no size>                    <no date>
Directory of bootflash:/
    1  -rw-       16083   Dec 6 2013 10:32:23 +00:00  cat6k-sw01-confg
    2  -rw-      357579   Feb 6 2014 12:11:09 +00:00  crashinfo_20140206-121109-GMT
    3  -rw-      302748   Feb 6 2014 11:56:20 +00:00  crashinfo_20140206-115620-GMT
    6  -rw-        1210   Apr 3 2014 12:57:27 +00:00  bootup.cfg
    7  -rw-      327751  Jan 24 2015 05:41:35 +00:00  crashinfo_20150124-054135-GMT
    8  -rw-      311305  Jan 24 2015 05:21:12 +00:00  crashinfo_20150124-052112-GMT
    9  -rw-      344631  Feb 17 2015 13:16:53 +00:00  crashinfo_20150217-131653-GMT
   10  -rw-      320713  Feb 17 2015 13:20:00 +00:00  crashinfo_20150217-132000-GMT
   11  -rw-      359965   Mar 3 2015 15:38:46 +00:00  crashinfo_20150303-153846-GMT
   12  -rw-      306904   Mar 3 2015 15:42:01 +00:00  crashinfo_20150303-154201-GMT
   13  -rw-      401966  Mar 19 2015 00:24:25 +00:00  crashinfo_20150319-002425-GMT
   14  -rw-      316930  Mar 19 2015 00:27:37 +00:00  crashinfo_20150319-002737-GMT
65536000 bytes total (62163980 bytes free)
Directory of disk1:/
    1  -rw-        9269   Oct 5 2012 10:06:18 +00:00  05-Oct-2012.cfg
    2  -rw-           0  Mar 18 2013 07:23:52 +00:00  ace-180313
    3  -rw-         916  Aug 14 2013 08:14:44 +00:00  sre-v-k9.smv.1.0.2.key
    4  -rw-           7  Aug 14 2013 08:49:46 +00:00  test.txt
512098304 bytes total (512065536 bytes free)
Directory of sup-bootdisk:/
    1  -rw-    33554432  Apr 11 2011 09:03:30 +00:00  sea_console.dat
    2  -rw-    71094564  Apr 11 2011 09:06:34 +00:00  s72033-ipservicesk9-mz.122-33.SXI5.bin
    3  -rw-    33554432  Apr 11 2011 16:28:22 +00:00  sea_log.dat
    4  -rw-        5610   Jun 1 2011 11:42:16 +00:00  01jun2011.cfg
    5  -rw-      200465  Jun 29 2011 14:32:16 +00:00  debuginfo_20110629-143214-UTC
    6  -rw-      381102   Feb 6 2014 12:11:08 +00:00  crashinfo_20140206-121109-GMT
    7  -rw-      408951  Jan 24 2015 05:41:34 +00:00  crashinfo_20150124-054135-GMT
    8  -rw-      377856  Feb 17 2015 13:16:52 +00:00  crashinfo_20150217-131653-GMT
    9  -rw-      371842   Mar 3 2015 15:38:46 +00:00  crashinfo_20150303-153847-GMT
   10  -rw-      392284  Mar 19 2015 00:24:24 +00:00  crashinfo_20150319-002425-GMT
1024557056 bytes total (884146176 bytes free)
Directory of sup-microcode:/
    1  -r--    23852114                    <no date>  DRACO2_MP
    2  -r--     9331982                    <no date>  CHEVYS-LC
    3  -r--    11309986                    <no date>  C2LC
    4  -r--    10805714                    <no date>  SPLC
    5  -r--      333568                    <no date>  LCP_LX10100
    6  -r--      303500                    <no date>  LCP_LX1000
    7  -r--      325646                    <no date>  LCP_AX1000
    8  -r--      376656                    <no date>  LCP_AX10100
    9  -r--      366718                    <no date>  LCP_CPFAB
   10  -r--      747470                    <no date>  LCP_CPGBIT
   11  -r--      483470                    <no date>  LCP_CP10G
   12  -r--      809230                    <no date>  LCP_CPMBIT2
   13  -r--      896238                    <no date>  LCP_CPMBIT
   14  -r--     1274158                    <no date>  LCP_CPXBIT
   15  -r--       65318                    <no date>  LCP_ABOOT
   16  -r--       60490                    <no date>  LCP_BOOT
61342258 bytes total (0 bytes free)
Directory of const_nvram:/
    1  -rw-        2716                    <no date>  vlan.dat
129004 bytes total (126288 bytes free)
Directory of nvram:/
 1918  -rw-       20812                    <no date>  startup-config
 1919  ----        1964                    <no date>  private-config
 1920  -rw-       20812                    <no date>  underlying-config
    1  ----         141                    <no date>  persistent-data
    2  ----           0                    <no date>  rf_cold_starts
    3  -rw-        4545                    <no date>  ifIndex-table
1964024 bytes total (1934028 bytes free)
Directory of dfc#2-bootflash:/
No files in directory
15990784 bytes total (15990784 bytes free)
Directory of dfc#3-bootflash:/
    1  -rw-      256881   Apr 1 2015 19:02:10 +00:00  crashinfo_20150401-190210-GMT
15990784 bytes total (15733772 bytes free)
Community Member
There are crashinfo files
There are crashinfo files generated. Extract them and send them to TAC. They will be able to help you to check if hardware or software caused the crash.
124
