Ask the Expert- configuration and troubleshoot WSA and https proxy
Community Member
Cheapest switch that will run ACLs on ports ?
I need the ability to restrict traffic between 2 LAN segments. I want to do this with dedicated hardware. I acheieved this using a 48 port 3750 switch with ACL's configured (spare hardware at the time), with 2 ports used (one connected to LAN A, one to LAN B). This is a waste of hardware.
I don't need any routing capablity in this device, so I am thinking I will replace it with the smallest (cheapest) switch capable of running ACL's on ports. I'm not sure all CISCO switches can do this ?
I currently apply the restrictions by host-host ip and the rules are not protocol specific. If I wanted to make the rules specific to certain protocols, can ACL's in switches do this ? or would that require a router ?
Super Bronze
Re: Cheapest switch that will run ACLs on ports ?
If the 3750 worked for you, so should the 3560s. If you don't need multiple gig ports nor many ports, there's the 8 port model. A 2960 -L switch might work for you too. Available modules also include 8 port variants; in both 100 or gig models.
Community Member
The switches vary on the number of access list values and masks they can handle, so it kind of depends on how big these access lists get.
However for a device dedicated to this purpose only I think a 2960 might work fine. Though note they don't do it vlan access-map style, only per interface.
bench2960#show platform acl usage 0
IPV4/MAC ACL TCAM USAGE:
ACL Type Label Entries Used
L3INPUT 3 (P) 3
Used Available Total
Mask 30 354 384
Value 30 354 384
IPV6 ACL TCAM USAGE:
Mask 5 2 7
Value 5 12 17
bench2960#show platform acl usage 1
Mask 27 357 384
Value 27 357 384
Mask 5 2 7
Value 5 12 17
181
