Choice of multiple default gateway
If I have two default route (D1 and D2) with two subnet connected (S1 and S2), is there a way to forward traffic through D1 or D2 with reference to the sender IP, that is network hosts belonging to S1 have default route D1 and hosts belonging to S2 have default route D2?.
Thank you.
Best regards.
Massimiliano.
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: Choice of multiple default gateway
Hi Massimiliano
You can use PBR (Policy Based Routing) to achieve this.
S1 = 192.168.5.0/24
S2 = 192.168.6.0/24
access-list 101 permit ip 192.168.5.0 0.0.0.255 any
access-list 102 permit ip 192.168.6.0 0.0.0.255 any
route-map DEFR permit 10
match ip address 101
set ip next-hop
route-map DEFR permit 20
match ip address 102
set ip next-hop
Then you apply the policy onto the relative interface ie.
int fa0/0
ip polict route-map DEFR
Jon
Hi Massimiliano
S1 = 192.168.5.0/24
S2 = 192.168.6.0/24
set ip next-hop
set ip next-hop
int fa0/0
Jon
Hi Jon,
Thank you.
Can I use PBR on switches Layer 3 also?
Can I apply route map to interface VLAN?
Best regards.
Massimiliano.
Hall of Fame Super Silver
Massimiliano
Yes you should be able to use PBR on most layer 3 switches. Note that you may need to adjust the SDM template (to use the routing template) on some of the switches to get support for PBR.
Rick
Thank you Rick.
Best regards.
Massimiliano.
156
