Community Member
cip card
How do we find out the serial no. for a CIP card on a cisco 7500 router. Please help.
Thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
cip card
I am not confident that there is a way to find the serial number for this card other than visual inspection of the card. I am pretty sure that the show inventory command does not work on the 7500. You might try commands like show diag but I am not confident that you would get the serial number that way.
Rick
1 REPLY
cip card
Rick
183
