05-27-2007 10:07 PM - edited 03-05-2019 04:19 PM
Dear,
Yesterday, i faced problem in router. I saw on router only pwr led blink I ping router ip giving request timed out Then i reboot my router & tired to ping it's working fine but what was the problem in router. How can i check. pl.give me sollution.
Thanks in advance.
05-27-2007 10:13 PM
Upendra,
Did you check the logs before rebooting the router. Do you have the logs with you. As per the explanation that you gave, it could be that router's interface hanged or the IOS got hanged and when you rebooted the router, they both reinitialized and the things started working. Without checking the logs its very hard to tell you the exact reason.
-amit singh
05-27-2007 11:02 PM
Dear
can you tell me how can i check log.which command useful for this. i think show log
i tried but there is no log related to ios & other interface.
05-27-2007 11:19 PM
Dear
I want to know. what was the reason for the same. pl. give me sollution
05-27-2007 11:33 PM
Hi Upendra,
you find any logs when you restarted the router, b4 restarting the router, if you face such of problem, you should always check the logs "show logging", that will help you to troubleshoot in most of the time. so next time when you face such kind of probz, juz see the log, because once you restart the router, all the logs getz cleared, as it is not stored on the router permanently.
05-28-2007 12:17 AM
Dear
as per your suggestion there is no way to check what was the problem in router.
05-28-2007 12:19 AM
YES, you can't come to know unless you check the log b4 rebooting the router.
05-28-2007 01:07 AM
When cisco router get hang, even we can not enter into the router. it wont allow Console also. So how come we can check Log
05-28-2007 01:58 AM
Hi Suresh,
upendra has never mentioned that the router got hang, he has just mentioned that ping came with an reply "Request timed out", that doesn't mean that router got hang. so it always a best practice that you see the log b4 rebooting the router or a switch. that will certainly help you to identify the problem.
